okgultekin_44
MIPI CSI-2 TX Configuration
Hello everyone,
I'm trying to use csi-2 tx subsytem in my design. As a input video source, I am using Video Test Pattern Generator.
Firstly I am configuring TPG IP.
XPAR_V_TPG_S_AXI_CTRL_BASEADDR + 0x0010 ,0x2D0 // Height 720
XPAR_V_TPG_S_AXI_CTRL_BASEADDR + 0x0018 ,0x438 // Width 1080
bla bla bla (background fforeground patterns, mask id, motion speed... etc)
XPAR_V_TPG_S_AXI_CTRL_BASEADDR + 0x0040, 0x0 // Color Format RGB
XPAR_V_TPG_S_AXI_CTRL_BASEADDR + 0x0098, 0x1 // Enabled Input
bla bla (pass throught Start/End X Y, dynamic range. .. etc)
XPAR_V_TPG_S_AXI_CTRL_BASEADDR + 0x0000, 0x80 // Restart TPG
XPAR_V_TPG_S_AXI_CTRL_BASEADDR + 0x0000, 0x01 // Start TPG
CSI-2 TX subsytem configuration comes after TPG configuration.
Disable Interruption
Controller is ready
Enable soft reset
Disable soft reset
Set 4 Lanes
Enable Global Interruption
Enable the core
SP DataType 0x24 RGB888
And also I added ILA cores to monitor axis video stream signals between TPG and CSI-2 TX cores.
To start video transmission, TUSER signal should be logic high but newer rise to high state.
Is there any problem about my configuration?
And is there any reference design and axi stream code about csi-2 tx
karnanl
Hello @okgultekin_44
Unfortunately, you have to install Vivado 2019.1, and generate the example design yourself.
Just for your reference, attached testbench RTL file generated from 2019.1.
I believe you can use it with 2018.3 simulation too, but I've never try the simulation myself. : -)
Please note:
# Xilinx only provided two configuration CSI-2 TX IP for simulation.
# We cannot run the example design simulation usinh only this single testbench RTL.
Thanks & regards
Leo
Versal Blogs
karnanl
Please try to run MIPI CSI-2 TX Subsystem Example design simulation. It is a good start point.
We provided 2 Example Design configuration
   A) 1 Lane RGB888 1 Pixel Mode
   B) 4 Lane YUV422 4 Pixel Mode
Both configuration using AXI4 stream I/F. See also PG260 Chapter 5. (https://www.xilinx.com/support/documentation/ip_documentation/mipi_csi2_tx_subsystem/v2_0/pg260-mipi-csi2-tx.pdf)
Looking at your ILA waveform, it seems that TUSER is never asserted.
Perhaps doing some simulation , before HW verifications will help.
Leo
Versal Blogs
okgultekin_44
@karnanl  thank you for your reply.
Unfortunately, I couldnt find any example design.
When I right click on mipi csi2 tx subsystem IP, I counldnt find any example design.
karnanl
What is your Vivado version ? Example Design is available in 2019.1 IP.
Please see also IP change log :
2019.1:
* Version 2.0 (Rev. 5)
* New Feature: Added example design
* Revision change in one or more subcores
Leo
Versal Blogs
okgultekin_44
Hello @karnanl,
Im using old version of vivado (18.3)
Is there any way to get example design without upgrade vivado? maybe a link or github?
Thx for your help
karnanl
Please note:
Thanks & regards
Leo
Versal Blogs
okgultekin_44
thank you @karnanl  !
