09-23-2020 02:26 AM
Dear Sir,
I am using ZCU102 and LI-IMX274MIPI-FMC V1-1 for testing the MIPI IP. I have already followed the steps in PG232 to generate the elf and bit file. I have downloaded the bit file by xsdb.
I have already generated the mipi example program. How can I download the mipi example program by xsdb or vivado command line ?
Teddy.
09-24-2020 02:00 AM
I have solved the problem. I saw the VITIS has generated the BOOT.BIN in the mipi csi2 example. I have put it in the SD Card then ZCU102 can boot up the demo via the SD Card.
09-24-2020 01:57 AM
Hello @teddywhy
After you generated bit/elf file successfully,
Could you please follow steps mentioned in PG232 Chapter 5 "Running the Design on Hardware" ?
Thanks & regards
Leo
09-24-2020 02:00 AM
