dhakalb
MIPI csi-2 rx tuser[0] not toggling at FS
I am using vivado 2019.2 and using mipi csi rx IP to capture frames from mipi camera. Pipeline is simple mipi csi rx -> frame buffer write.  I am unable to capture the frames so i probed video out from mipi with system ILA, I do not see the tuser[0] bit toggling at the frame start. All the other buses looks fine. Have anyone run into such problem? Any idea what could be causing such issue?  I have attached the screenshot of the ILA out and csv file for the stream.
Tags (2)
dhakalb
Thank you for the suggestion. After doing the patch I was able to see the tlast bit toggling. There was an additional problem with the documentation with the camera. After setting the PLL multiplier half of the documented value, I was able to capture the frame from the camera.
Thank you!
karnanl
Hello @dhakalb
MIPI CSI-2 RX subsystem has a few known issues in 2019.2 version.
Have you apply the IP patch from : https://www.xilinx.com/support/answers/73100.html ?
If you haven't, please apply the patch and re-do the test.
Leo
Versal Blogs
dhakalb
Thank you!
