10-15-2019 07:34 AM - edited 11-18-2019 01:28 AM
I tried a simple baremetal displayport design from Adam Taylor on the Ultra96 v1 (https://github.com/ATaylorCEngFIET/Ultra96V2_DisplayPort). It works when build with 2018.2 and 2018.3 but NOT with 2019.1. In 2019.1 the app is stuck in an ISR.
I also tried the VCU TRD for the ZCU106 board with DP output, which works fine in the 2018.3 pre-compiled version but not with 2019.1. The screen stays black. I tested both with 1920x1080 resolution.
10-15-2019 02:06 PM
Hi @axelvolley
What kind of monitor do you use ?
Also, how do you connect to this monitor ? DP cable ? HDMI cable with DP-HDMI active adapter ? HDMI cable with DP-HDMI passive adapter ?
10-16-2019 12:25 AM
Ultra96: miniDP -> DP
ZCU106: DP -> DP
10-20-2019 11:29 PM
In all cases I used a native 1920x1080p resolution monitor (IIyami T2435) with DisplayPort input and a 1m DisplayPort cable with no adaptors.
10-22-2019 02:05 AM
Hi @axelvolley
Uhm. it's a little strange.
Would you share the following register's value ?
- DP_MAIN_STREAM_M_VID
- DP_MAIN_STREAM_N_VID
10-24-2019 01:18 AM
In case of the Ultra96 example which uses a resolution of 1280x720x60p. The values are:
DP_DP_MAIN_STREAM_N_VID = DP_BASEADDR + 0x1B4: 0x00041eb0
DP_DP_MAIN_STREAM_M_VID = DP_BASEADDR + 0x1AC: 0x0001220a
and of course for both builds (2018.3 and 2019.1). As I said these are identical designs, except for the IP cores.
Maybe I need to better explain what works and what not. The Live-video feed for the "vcu_qt" app of the "rdf0428-zcu106-vcu-trd-2019-1_v2.zip" downloaded from the Xilinx website doesn't work (alwasy black), but for the "rdf0428-zcu106-vcu-trd-2018-3.zip" it does.
The Ultra96 design explained above also uses the DPs live video feed.
10-24-2019 03:10 PM
Hi @axelvolley
I suspected behaviour of DP Tx's driver in 2019.1.
My query is to confirm suitable setting or not by this driver.
M_VAL / N_VAL * reference clock (270MHz) = 74.25MHz
It's a correct pixel clock of 1280x720p60.
So, I don't have any idea to resolve it...
10-24-2019 11:25 PM
Hi watari,
can you confirm that the LiveVideo feed from your ZCU106-VCU-TRD, available from your website ("rdf0428-zcu106-vcu-trd-2019-1_v2.zip") works over the DisplayPort?
Otherwise I am wondering if my two boards an Ultra96 and a ZCU106 both have the same hardware problem when building with 2019.1 or am I the only one using the ZCU106-VCU-TRD?
11-08-2019 04:15 AM
Hello @axelvolley
I tested DPDMA example design based on PS DisplayPort Controller on ZCU106 board with Vivado 2019.1.
I did not observed any issues with PS DisplayPort of Zynq.
I have followed following procedure :
1. Created project for ZCU106 board in Vivado 2019.1
2. Created block design and In block design added Zynq US+ MPSOC PS IP.
3. Run Block automation
Click on Run Automation
Select apply board preset option and click OK
4. Connect pl_clk to maxihpm0_fpd_aclk and maxihpm1_fpd_aclk as follows:
Clock connections
5. Run Synthesis. After synthesis completion export hardware ( File > Export > Export Hardware) without selecting bitstream option and Click OK.
6. Launch SDK from Vivado (File > Launch SDK) and Click Ok with default options
7. In SDK, create New Board Support Package (File > New > Board Support Package). Select options as follows and Click Finish:
It will bring up Board Support Package (BSP) Setting (or you right click on BSP select Board support package setting to get this window shown below) change psu_dp driver to dppsu from avbuf and click Ok. It will automatically build BSP.
psu_dp driver for PS DP
7. Double click on system.mss and click on Import DPDMA example
DPDMA example
Tick option below and Click Ok.
8. Connect DisplayPort Monitor to ZCU106 and test example design. It should show half green display on your monitor and UART should show following log:
DPDMA Generic Video Example Test Generating Overlay..... HPD event .......... ! Connected. Lane count = 2 Link rate = 20 Starting Training... ! Training succeeded. DONE! .......... HPD event Successfully ran DPDMA Video Example Test
11-18-2019 01:00 AM
Hi @axelvolley
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
**~ Got a minute? Answer our Vitis HLS survey here! ~**
11-18-2019 01:26 AM
I mentioned two designs, that use live-video feed to the display port, for example generated by the TPG. Live video uses "avbuf" config.
I mentioned two designs for which it doesn't work under 2019.1 but works for 2018.3.
I am not sure why you showed how the example design works! I tried that of course for 2019.1 and 2018.3 and had no problems either. The problem is the live-video feed shown in the two above mentioned designs.
11-18-2019 06:30 AM
hi @axelvolley
You mentioned the VCU TRD 2019.1 which is not using the live input. Check on the design:
So the test from @bpatil is relevant if the VCU TRD is failing for you. So it might worth for you do use the same as a first step.
11-18-2019 11:37 PM
Ok may be I am jumping to consclusion about the live video feed.
I also said that I tried the example DP design.
As a matter of fact I still have two examples, as stated in my 1st email that don't work with the DP.
The design by Adam Taylor was checked multiple time with 2018.2, 2018.3 and 2019.1 and it never worked with 2019.1.
I also mentioned that the VCU TRD for the ZCU106 board downloaded here https://www.xilinx.com/member/forms/download/design-license-xef.html?filename=rdf0428-zcu106-vcu-trd-2019-1_v2.zip doesn't work when using the DP output. Can you confirm?
11-19-2019 01:42 AM
HI @axelvolley
Unfortunnatly I have no ZCU106 with me at the moment. But maybe @bpatil can try quickly?
It might just be that the VCU TRD has the displayport controller disabled in 2019.1 because it is not really what we want ot showcase here. But with that said, I am quite sure I ran the VCU TRD with 2019.1 and I had an output. However you need to enable the display first, so it might no come up by default
You can try the following on the ZCU106:
11-25-2019 04:42 PM
Hi @axelvolley
I evaluated ZCU106 VCU TRD 2019.1 via gstreamer with LCD monitor (Supported 4K resolution) on DispalyPort Tx and HDMI Tx.
It worked fine.
So, at least, it doesn't have any problem about DP Tx on MPSoC...
Sorry I didn't read all posts on this thread, if you already mentioned important information...
12-03-2019 08:31 AM
Hi @axelvolley
Thanks and Regards,
