Problem with using EDK in system generator
I have imported an XPS project to EDK processor in system generator. System generator sucessfully generates the bitstream. It includes all the blocks I have put in my SysGen design and runs properly on my Virtex II Pro board. The only problem is that it does not execute my C-code from the XPS project!
Any idea on this, please?
I recommend that you walk through the EDK import tutorial.  This may help you find why your code isn't being include.
Chris
Versal ACAP: AI Engines | Embedded SW Support
