hitpmpm@163.com
Some concepts in image processing
1.How to understand the definition of real-time in image processing, how many fps is the frame rate to be real-time? Where are the specific definitions? 2.I am doing moving target detection, and detecting the video data collected by the camera. The display can display the result correctly. Is this called real time? 3.The resolution of my monitor is 1080*720/60hz. How should I calculate my processing frame rate? 4.How is the speedup in image processing defined? Is the processing speed of zynq compared with arm, or is it compared with the experimental results on a PC? thanks!
florentw
Hi hitpmpm@163.com ,
[Florent] - Real time video processing means that you are doing your video processing on the fly so you need to have the output as fast as the input. I does not really depends on the FPS.
But the more frame you can process per second, the more information you can collect. So the higher FPS you can have, the best it is. It will depend on the requiremnt of your application.
Also note that the human high cannot really detect changes below 25 FPS, which is what is commonly used for animated movies. So if you go below 25 FPS, your video won't seems continuous.
Then you also might want to have as little latency as possible.
[Florent] - If the result is sent at the same frequency than the input, yes this is real time processing.
[Florent] -  It will be the output of your design. How many FPS can you process?
[Florent] - It depends on what is your benchmark. If you want to speed up image processing from a PC with a FPGA you will compare before/after using the FPGA
florentw
florentw
Hi hitpmpm@163.com
Is everything clear for you on this topic?
Thanks and Regards,
hitpmpm@163.com
thanks you sir!
hitpmpm@163.com
Hello, sir. I want to know where there is a definition of real-time 25fps, I am writing a thesis, I don’t know which book or paper to quote.
florentw
HI hitpmpm@163.com
I do not have any document. I believe looking for bibliograpy is part of the thesis wok
