12-04-2009 07:53 AM
Hi everyone,
I'm new to System Generator. I just used Xilinx ISE to design FPGA in VHDL before with Spartan 3E starter kit. But now I found out System Generator with more useful math block.
But I really have many question that keep spining in my mind although I have read all the pdf starter guide and lab module:
1. Is it ok to use sin, cos and gaussian noise of xilinx system generator block with Spartan 3E starter kit?
2. I could find exp function in Xilinx block, so does that mean exp function does not appear in Xilinx block?
3. Does it have any way to download to FPGA directly? I think I have to export model of System Generator to VHDL code, and then make a component in ISE.
I really appreciate any helps.
12-06-2009 11:48 AM - edited 12-06-2009 11:50 AM
Hi!
I'm not an expert so somebody might correct me.
1. sin and cos can be computed using CORDIC or with the DDS Compiler. Latter is basically a look up table, and depending on the resolution you require it will occupy some BRAM-s and minimal logic in your FPGA. CORDIC computes the values, using no BRAMs but more logic (adders and shifters). You should use resource estimator to see how much resources a certain configuration will eat up. Depending on precision requirements and device size it might fit into a Spartan 3E.
The White Gaussian Noise Genearator seems quite complicated. As i see it uses at least 4 multipliers and lots of logic. Check with resource estimator if it will fit.
2.With the CORDIC 4.0 block from the Xilinx Blockset you can compute sinh and cosh (e^x = sinh x+ cosh x).
3.Double click your System Generator block and set Compilation to Bitstream then System Generator should produce a downloadable .bit file for the selected device. You can download the file with Impact.
Hi!
12-10-2009 01:21 AM
Hi bagojfalvibagoj,
I really appreciate your help. I forgot sinh and cosh function. My problems have solved!
Phong Duong
12-10-2009 01:36 PM
Regarding your question 3: you can also use the hardware cosimulation in sysgen to download your design to FPGA and test it in HW. The snapshot below shows the compilation target for HW cosimulation.
