Standalone DisplayPort greyscale display not working
I am trying to use the Y only mode for the DP on a ZCU104. I tried a configuration for both graphics and video channel.
Here is the configuration for the non-live video
Status = XDpDma_SetVideoFormat(DpDmaPtr, MONOCHROME);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
/* Set the format graphics frame for Video Pipeline*/
Status = XAVBuf_SetInputNonLiveVideoFormat(AVBufPtr, MONOCHROME);
return XST_FAILURE;
XAVBuf_SetOutputVideoFormat(AVBufPtr, YOnly_8BPC);
XAVBuf_InputVideoSelect(AVBufPtr, XAVBUF_VIDSTREAM1_NONLIVE,
XAVBUF_VIDSTREAM2_NONE);
I have a version for the non-live graphics as well where I try BPP8 format , in the corresponding functions
This is how I populate the buffer:
u8 *GraphicsOverlay(u8* Frame, Run_Config *RunCfgPtr)
	u64 Index;
	u8 *Yonly;
	Yonly = (u8 *) Frame;
		 * Red at the top half
		 * Alpha = 0x0F
	for(Index = 0; Index < (BUFFERSIZE) ; Index ++) {
		Yonly[Index] = (u8)Index;
	return Frame;
How can I obtain a greyscale display, in each case my screen is purple?
I used the code from here: https://forums.xilinx.com/t5/Video-and-Audio/Displayport-standalone-on-ZCU104/m-p/975064, the RGB example works.
thomas66
Hi Szliard,
I tried your code (had to add the xdpdma_interupt.c from the driver example) but did not even get the DP output to work. Which tool version do you use? (I use 2019.2)
I then tried to patch the driver example to grayscale (the default with the green bar on the bottom half of the screnn works) but do get a black screen only.
Just use the RGBA8888 format and set the RGB components to the same value to get gray.
Best Regards,
Thomas
thomas66
Hi Szilard,
Did you try to keep the output format at RGB?
XAVBuf_SetOutputVideoFormat(AVBufPtr, RGB_8BPC);
Your Monitor is (most likely) RGB and so should the output format, I belief.
If this doesn't work, can you share the source code? (just the .c and .h files from your Vitis/XSDK project)
Best Regards,
Thomas
Hi Thomas,
This is how my screen looks
Something incremental is happening it is still not greyscale
I attached my source codes, I am trying this on the graphics channel.
Szilard
thomas66
Hi Szliard,
Best Regards,
Thomas
Hi Thomas,
I was hoping to find a solution to use a single plane, I had the same black screen problem, but I will use then the RGB888 solution.
Thank you,
Szilard
