mrbietola
Switch between two axi stream videos
Hi, thwere is not such a component in EDK, i would select between 2 video streams, how is the correct way to do this?
My idea is, when i need to change video, i wait for the current video to end the current frame ( wait for sof high) then i look at the second video stream and discard data until the new sof, then i will propagate the output...
balkris
you need to create 2 frame buffer. You may use external memory or internal memory in ping pong . write alternate frame in these buffer and read alternately for processing.
Thanks and Regards
Balkrishan
mrbietola
i don't want to introduce a frame of latency between input and output, i have this configuration
video to axi -> scaler -> triple frame buffer -> axi to video
the latency is only 1 frame and is the maximum allowed
martinthompson
Your plan sounds fine - now just write the code and test it :)
Martin Thompson
martin.j.thompson@trw.com
http://www.conekt.co.uk/capabilities/electronic-hardware
