Switching Resolution on Display Port RX subsystem 2.1
Dear all,
Does the IP support more than one resolutions?
I mean, in our application we need to support 3200x1200 at 120fps,
but we'd like to know if we can support for example 1600x1200 at 120fps without regenerating / reconfiguring the DiP IP core.
Andrea
Mentor
Mentor
Re: Switching Resolution on Display Port RX subsystem 2.1
Hi @andreac_avnet
Can you use EDID for your application ?
If yes, I guess you can switch resolution on DP Rx IP.
However, even if DP Rx can support these resolutions, I suggest to consider pixel clock and SSC rate.
Mentor
Mentor
Hi @andreac_avnet
