TPG parameters
I have a design with tpg and vdma. I get only the following paramets not all for tpg
root@autoref:/home/yavta-master# ./yavta --no-query -l /dev/v4l-subdev0
Device /dev/v4l-subdev0 opened.
control 0x00980001 User Controls min 0 max 0 step 0 default 0 current n/a.
control 0x0098c901 Test Pattern: Cross Hairs min 0 max 1 step 1 default 0 current 0.
control 0x0098c902 Test Pattern: Moving Box min 0 max 1 step 1 default 0 current 0.
control 0x0098c903 Test Pattern: Color Mask (RGB) min 0 max 4 step 0 default 0 current 0.
control 0x0098c907 Test Pattern: Motion Speed min 0 max 255 step 1 default 4 current 4.
control 0x0098c908 Test Pattern: Cross Hairs Row min 0 max 4095 step 1 default 100 current 100.
control 0x0098c909 Test Pattern: Cross Hairs Colum min 0 max 4095 step 1 default 100 current 100.
control 0x0098c90a Test Pattern: Zplate Horizontal min 0 max 65535 step 1 default 30 current 30.
control 0x0098c90b Test Pattern: Zplate Horizontal min 0 max 65535 step 1 default 0 current 0.
control 0x0098c90c Test Pattern: Zplate Vertical S min 0 max 65535 step 1 default 1 current 1.
control 0x0098c90d Test Pattern: Zplate Vertical S min 0 max 65535 step 1 default 0 current 0.
control 0x0098c90e Test Pattern: Box Size min 0 max 4095 step 1 default 50 current 50.
control 0x0098c90f Test Pattern: Box Color(RGB/YCb min 0 max 16777215 step 1 default 0 current 0.
control 0x009e0001 Image Source Controls min 0 max 0 step 0 default 0 current n/a.
control 0x009e0901 Vertical Blanking min 3 max 8159 step 1 default 100 current 100.
control 0x009e0902 Horizontal Blanking min 3 max 8159 step 1 default 100 current 100.
control 0x009f0001 Image Processing Controls min 0 max 0 step 0 default 0 current n/a.
control 0x009f0903 Test Pattern min 0 max 15 step 1 default 9 current 9.
18 controls found.'
can you tell me what I am missing? I am using linux-4.0 and vivado 2017.1
Jothi
Everything in the list you provided, looks to be related to the Test Pattern Generator (TPG).  You can find more information in PG103 Video Test Pattern Generator or on the TPG V4L2 Wiki Page.
Also of note:  At this point 2017.1 is quite old and the Video Drivers have had significant updates.  I recommend moving to the latest version (2019.1 or 2019.1) to get all the fixes and improvements.
Chris
Versal ACAP: AI Engines | Embedded SW Support
Chris
Hi @jothiadithya
If your question is answered or your issue is solved, please kindly mark the response which helped as a solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
