boris.barak@vitec.com
Use pixel repetition with hdmi_rx_ss for 480i/576i support
We are using Zynq xczu4ev-fbvb900-1-e chip in our HDMI RX system solution.
Vivado version is v2018.3.
hdmi_rx_ss is used with conjunction of the software drivers from Xilinix.
The output of hdmi_rx_ss is native video one.
It seems hdmi_rx_ss issues wrong sample values in the case of 480i/576i input of YUV422 or YUV444 color scheme (see attached).
It's obviously could be seen on ILA snapshot view, sampling hdmi_rx_ss outputs.
In the case of the rest of the formats everething seems good.
Attached Vivado ILA samples directly after mpsoc_wrapper (before any user logic).
The input video pattern is color bar 100%.
It definitly can be seen a good yellow color for the second color bar strip in the case of 480p.
On the other hand we can see a bad color for such case in 480i.
In addition repetited pixels are not the same !
Is any known issue exists here ?
Best regards.
Boris Barak.
Tags (2)
xud
Hi boris.barak@vitec.com
Please be aware of following notes from PG235 :
Note: Using AXI4-Stream, pixel repetition only supports RGB and YUV444 color space, but not 12-bitYUV422. Using the native interface, you can create customized pixel replication logic that supports allcolor spaces including 12-bit YUV422.
I've realized that in the case of 480i/576i YUV422 pixels samples are repeated in the following way:
...PIX3=[V2Y3V2Y3],PIX2=[Y2U2Y2U2],PIX1=[V0Y1V0Y1],PIX0=[Y0U0Y0U0]
I'm wondering if this structure is menthioned somewhere in in the datasheet.
Finally my pixel subsampling mechamism (1440=>720) is considering this structure.
There is another issue to verify.
In the test the hdmi source carries pattern of 100% color bar .
However the samples come from "hdmi_rx_ss" core, over native_video, are slightly different.
This can be seen on the attached ILA snapshots.
Indeed, for the second color (yellow)  strip we get the following samples: Y=0xD21, U=0x101, V=0x924.
Normalizing this to 8-bit gives: Y=0xD2, U=0x10, V=0x92.
Then converting to RGB : R=235, G=235, B=10.
B-level is supposed to be zero here, isn't it ?
Can you check ASAP, please ?
Best Regards.
Boris Barak.
xud
