VDMA configure in Python
Hello, i am trying to configure the AXI VDMA in Python with the overlay of the following design, but i get an error.
designdesign
jupyterjupyter
Tags (2)
kvasantr
Hello auto.giannis@gmail.com
I am not sure what exactly is your development activity here, but this is not something supported or tested by Xilinx itself. What information are you exactly trying to read from .bit file?
Kunal
I am trying to load the overlay and the bitstream file has the design information.
florentw
HI auto.giannis@gmail.com
I am not sure how to use the AXI VDMA under python/PYNQ.
However, could it be that the issue is happening because you didn't connect the interrupt signals (s2mm_introut, mm2s_introut)? This might be the root cause looking at the error message.
Florent
florentw
Did you make any progress on this? It would be great if you could share your findings with the community
Florent
I haven't continued this project.
Since i don't need the interrupt signals why should I connect them?
florentw
Hi auto.giannis@gmail.com
Because I believe that the PYNQ workflow is using linux and the linux driver for the AXI VDMA requires the interrupts to be connected
Florent
I created another design where i use a test pattern generator to pass the signal through HDMI on a monitor.
I am trynig to configure VDMA with pynq video library but the monitor is still blank.
