huyongwei
VDMA with TPG
    When I make an example with VDMA 、TPG、VTC and Video Out IP core。my system block is like this。just flow
when I use SDK run the VDMA example (xaxivdma_example_intr.c),during I config VDMA core with the function int XAxiVdma_SetFrmStore(XAxiVdma *InstancePtr, u8 FrmStoreNum, u16 Direction);(in xaxivdma.h)
XAxiVdma_Channel *Channel;
if(FrmStoreNum > InstancePtr->MaxNumFrames) {
return XST_FAILURE;
Channel = XAxiVdma_GetChannel(InstancePtr, Direction); // ERROR
if (!Channel) {
return XST_FAILURE;
if(XAxiVdma_ChannelIsRunning(Channel)) {
xdbg_printf(XDBG_DEBUG_ERROR, "Cannot set frame store..."
"channel is running\r\n");
return XST_FAILURE;
if (!(Channel->DbgFeatureFlags & XAXIVDMA_ENABLE_DBG_FRMSTORE_REG)) {
"Frame Store Register is disabled\n\r");
return XST_NO_FEATURE;
XAxiVdma_WriteReg(Channel->ChanBase, XAXIVDMA_FRMSTORE_OFFSET,
FrmStoreNum & XAXIVDMA_FRMSTORE_MASK);
Channel->NumFrames = FrmStoreNum;
XAxiVdma_ChannelInit(Channel);
return XST_SUCCESS;
I get Channel with 0x19, mean  NULL.  Now how can I fix the problom?
Tags (2)
florentw
HI @huyongwei ,
Do you have any updates on this? Were you able to solve your issue?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
florentw
Hi @huyongwei ,
Can you share your full project?
You might want to refer to some video series I wrote related to the VDMA, this might help:
Video Series 24: Using the AXI VDMA in Triple Buffer Mode
Video Series 25: Debugging issues on the AXI VDMA IP
Video Series 26: Examples of advanced uses of the AXI VDMA IP
Florent
florentw
HI @huyongwei ,
Thanks and Regards,
Florent
huyongwei
Hello, @Moderator
Thanks for your reply, But my issue is'not be solved,Maybe the file xaxivdma_example_intr.c (API)can't be used in a baremetal system? Now I use Xli_IO.h for may VDMA's configuration. then everythings is going on well.
Thanks and Regards.
florentw
HI @huyongwei ,
xaxivdma_example_intr.c is for a baremetal application but you need to make sure the VDMA is properly connected (you have the interrupts connected properly in you HW).
Florent
luoyanghero
@florentw I meet the same question too. This is my question discription.
https://forums.xilinx.com/t5/Video/ZCU102-VDMA-test-failed/m-p/977233#M25453
troublesig
I have also encountered this problem. Is there a hardware project corresponding to vdma_example_intr.c?
