VTC core Max Lines number issue
My project should setup the VTC core IP in customer frame setting. Below setting did not work properly, but it will work great if I made the HActiveVideo low than 3820.
Anyone could help to solve this issue for HActiveVideo being larger or equal than 3856. Thank you.
freq. of vtc is 148.5 MHz
vtcTiming.HActiveVideo = 3856; /**< Horizontal Active Video Size */
vtcTiming.HFrontPorch = 88; /**< Horizontal Front Porch Size */
vtcTiming.HSyncWidth = 44; /**< Horizontal Sync Width */
vtcTiming.HBackPorch = 148; /**< Horizontal Back Porch Size */
vtcTiming.HSyncPolarity = 1; /**< Horizontal Sync Polarity */
vtcTiming.VActiveVideo = 1088; /**< Vertical Active Video Size */
vtcTiming.V0FrontPorch = 4; /**< Vertical Front Porch Size */
vtcTiming.V0SyncWidth = 5; /**< Vertical Sync Width */
vtcTiming.V0BackPorch = 36; /**< Horizontal Back Porch Size */
vtcTiming.V1FrontPorch = 4; /**< Vertical Front Porch Size */
vtcTiming.V1SyncWidth = 5; /**< Vertical Sync Width */
vtcTiming.V1BackPorch = 36; /**< Horizontal Back Porch Size */
vtcTiming.VSyncPolarity = 0; /**< Vertical Sync Polarity */
vtcTiming.Interlaced = 0; /**< Interlaced / Progressive video */
Hi Moderator,
Got it. Thanks a lot.
Hi p.ching.kuang@gmail.com
What vivado version are you using?
What do you mean by it does not work? Do you see any output from the VTC?
Are you sure this timing is supported by your monitor?
Thanks for reply, The vivado is 2015.4.
By the settings I list, the VTC will output waveform (checked by ILA ip) if "vtcTiming.HActiveVideo" is lower than 3820, otherwise the VTC will not output any waveform by ILA ip.
My monitor is customer's specific receiver, it could accepted the settings of VTC by HActiveVideo" lower than 3820 before.
Please help to slove this issue, otherwise the project will be terminated. Thank you.
Hi florentw,
Any update? thank you.
You might want to a later version. Then you need to make sure you change the configuration for Max clock per line to 8192:
You are probably set to 4096. But you horizontal resolution is going higher than this:
HActiveVideo + HFrontPorch  + HSyncWidth + HBackPorch = 3856 + 88 +44 + 148 = 4136
Hi Moderator,
Thanks for reply,
But, what do you mean for the later version? As I know, the VTC 6.1 did not update version for a long time from vivado 2014.x ~ 2019.x. Or which version of vivado will be update?
In addition, "You are probably set to 4096" indicated that should I try to make the resolution to be lower than 4097 for the current version of VTC6.1 ? At fact, for the previous message, I have said that the VTC will work properly if I make the value of HActiveVideo<=3820, but my project required to be larger HActiveVideo>=3856 ?
HI p.ching.kuang@gmail.com
p.ching.kuang@gmail.com wrote:
Hi Moderator,
Thanks for reply,
[Florent] - I recommend to use the latest version of vivado (i.e. 2019.1). As per the change log, there was some minor updates between releases, including support for 8K resolutions:
[Florent] - Yes you would need to have the total hresolution (i.e. hactive + hblank) to be max 4096.
Also, I have just check and in 2015.14 you can increase the Max clocks per line to 8192. Did you already done that?
Hi Moderator,
