banschu
Video Processing Subsystem v2.2 product guide missing
Where is the Video Processing Subsystem v2.2 Product Guide PG231?
My Documentation Navigator catalog is up to date, set to 2020.1, and the VPS 2.2 PG is listed. However, the web link redirects to a generic support page, and the downloaded PDF is corrupt (actually some HTML file).  Both are repeatable.
florentw
Hi @banschu
I have documented this issue in the documentation team.
In the mean time, you might be able to use the v2.3 as I do not think much changed in the VPSS between v2.2 and v2.3
https://www.xilinx.com/support/documentation/ip_documentation/v_proc_ss/v2_3/pg231-v-proc-ss.pdf
Florent
