jmcdstx
Video stream from ZCU106 VCU TRD 2019.2 Low-latency projects has "pulsing" effect
Using the NV12 and NV16 Low-latency projects of the VCU 2019.2 TRD, the streaming out put appears to pulse once a second. The GStreamer command line used for NV12  H.264 is:
gst-launch-1.0 v4l2src io-mode=4 device=/dev/video0 ! video/x-raw\(memory:XLNXLL\), width=3840, height=2160, format=NV12, framerate=60/1 ! omxh264enc qp-mode=auto gop-mode=low-delay-p gop-length=60 periodicity-idr=60 b-frames=0 target-bitrate=25000 num-slices=8 control-rate=low-latency prefetch-buffer=TRUE low-bandwidth=false filler-data=0 cpb-size=1000 initial-delay=500 ! video/x-h264, alignment=nal ! queue max-size-buffers=0 ! mpegtsmux name=mux ! rtpmp2tpay ! multiudpsink clients=192.168.1.219:5004,192.168.1.219:5006   buffer-size=60000000 max-bitrate=120000000 max-lateness=-1 qos-dscp=60 async=false
The pulsing interval can be changed by modifying the periodicity-idr parameter. Setting the value to 0 stops the pulsing but the video quality is much worse, and has a shimmering effect.
This issue is seen for the NV12 and NV16 low-latency projects for H.264 and H.265, for 4kp60 and 1080p60.
This issue is not seen in the HDMI RX project, but this project has significantly higher latency.
A sample video of the pulsing is attached.
Any ideas on how to eliminate the pulsing?
dhill972
I heard that this issue might be resolved by applying the patches that are contained in AR 73019, but I I have not tried this myself. I would recommend giving these a try. Please let us know if this helps.
watari
Hi @jmcdstx
How do you connect between ZCU106 and client machine by Ethernet ?
Are you using network hub ?
I encountered similar issue with NETGEAR's network hub on VCU TRD 2019.1.
It was broken packet by network hub and the route cause is performance issue of network hub.
Best regards,
dhill972
