dzungpv
XAPP794 upgrade to Vivado 2014.1
I am new in hardware design, but i am work in software for many year. Software always has backward with previous design but it not true with Vivado. I am working with XAPP794, i can build it with 2013.2 but i want to update to more recent version like 2013.3 or 2014.1 but failed after many try. To version 2013.3 error with fmc_imageon_vita_receiver.
Anyone success upgrade the xapp794 to more recent version?
balkris
XAPP794 are expected to use in tested version . Can you elaborate error message in dettail based on your message we will try to help you
Please make sure to upgrade all the IPs used by XAPP
Thanks and Regards
Balkrishan
florentw
Hi @dzungpv,
As @balkris, xapps are only supported for the version mentioned in the documentation.
Each version of vivado has a specific version for each IP. The xapp is build using a tcl script and tcl script need to mention the specific version of the IP. This is probably why it is not working for you.
The best way to use a newer version of vivado is to build the xapp794 with 2013.2 then open this project with a newer version of vivado. It should work. You might need to upgrade the IPs and make some required changes following the upgrade log.
Hope that helps,
Best Regards,
Florent
Florent
