jobincyriac
Xilinx MIPI TX Timing parameters(THS-PREPARE,THS-ZERO)
I am trying to Integrate MIPI CSI2 TX IP with cypress CX3 chip. In CX3 configurations it asks for the THS-PREPARE and THS-ZERO timing parameters of the transmitter. In xilinx MIPI data sheet I couldn't find these parameters. Can you help me in finding the correct parameter values for these?
Best Regards,
Jobin Cyriac.
karnanl
Hello Jobin @jobincyriac
For MIPI CSI-2 TX ( & MIPI D-PHY TX)
Current value for the following timing parameter are as follow
THS-PREPARE = (32'd85 + UI6);
THS-ZERO =  (32'd105 + UI6);
We do not put this in our PGs but all global timing parameters are set with value within the MIPI D-PHY specification ver1.1.
Thanks & regards
Leo
Versal Blogs
karnanl
Thanks & regards
Leo
Versal Blogs
florentw
Hi @jobincyriac,
Do you have any updates on this? Was the reply from @karnanl enough for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
