Xilinx ZCU106 HDMI display output
I'm trying to get the output from HDMI and running on the ZCU106. I am only interested in only the TX (output). My objective is to get a video output in my monitor by using GStreamer.
I am using the pre-built image. (xilinx-zcu106-2020.1)
Here is my kernel startup:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.4.0-xilinx-v2020.1 (oe-user@oe-host) (gcc version 9.2.0 (GCC)) #1 SMP Thu May 28 12:53:53 UTC 2020
[ 0.000000] Machine model: ZynqMP ZCU106 RevA
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] printk: bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 1000 MiB at 0x0000000034c00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 22 pages/cpu s49944 r8192 d31976 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1031940
[ 0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/ram0 rw cma=1000M
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x7bf00000-0x7ff00000] (64MB)
[ 0.000000] Memory: 2915400K/4193280K available (11644K kernel code, 672K rwdata, 3624K rodata, 704K init, 323K bss, 253880K reserved, 1024000K cma-reserved)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x2a8/0x42c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
[ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[ 0.008324] Console: colour dummy device 80x25
[ 0.012394] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[ 0.022756] pid_max: default: 32768 minimum: 301
[ 0.027480] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.034706] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.043433] ASID allocator initialised with 32768 entries
[ 0.047902] rcu: Hierarchical SRCU implementation.
[ 0.052860] EFI services will not be available.
[ 0.057239] smp: Bringing up secondary CPUs ...
[ 0.061938] Detected VIPT I-cache on CPU1
[ 0.061969] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.062318] Detected VIPT I-cache on CPU2
[ 0.062337] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.062660] Detected VIPT I-cache on CPU3
[ 0.062679] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.062726] smp: Brought up 1 node, 4 CPUs
[ 0.097066] SMP: Total of 4 processors activated.
[ 0.101739] CPU features: detected: 32-bit EL0 Support
[ 0.106843] CPU features: detected: CRC32 instructions
[ 0.111975] CPU: All CPU(s) started at EL2
[ 0.116024] alternatives: patching kernel code
[ 0.121536] devtmpfs: initialized
[ 0.129794] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.133890] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.164180] xor: measuring software checksum speed
[ 0.200859] 8regs : 2375.000 MB/sec
[ 0.240885] 32regs : 2724.000 MB/sec
[ 0.280917] arm64_neon: 2365.000 MB/sec
[ 0.280953] xor: using function: 32regs (2724.000 MB/sec)
[ 0.284827] pinctrl core: initialized pinctrl subsystem
[ 0.290651] NET: Registered protocol family 16
[ 0.295400] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.300506] audit: initializing netlink subsys (disabled)
[ 0.305968] audit: type=2000 audit(0.248:1): state=initialized audit_enabled=0 res=1
[ 0.313564] cpuidle: using governor menu
[ 0.317583] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.337583] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.338639] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.345308] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.351965] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.432236] DRBG: Continuing without Jitter RNG
[ 1.506815] raid6: neonx8 gen() 1544 MB/s
[ 1.574854] raid6: neonx8 xor() 1461 MB/s
[ 1.642892] raid6: neonx4 gen() 1480 MB/s
[ 1.710936] raid6: neonx4 xor() 1419 MB/s
[ 1.778975] raid6: neonx2 gen() 1123 MB/s
[ 1.847018] raid6: neonx2 xor() 1173 MB/s
[ 1.915052] raid6: neonx1 gen() 728 MB/s
[ 1.983115] raid6: neonx1 xor() 880 MB/s
[ 2.051184] raid6: int64x8 gen() 1162 MB/s
[ 2.119214] raid6: int64x8 xor() 760 MB/s
[ 2.187293] raid6: int64x4 gen() 977 MB/s
[ 2.255290] raid6: int64x4 xor() 733 MB/s
[ 2.323326] raid6: int64x2 gen() 677 MB/s
[ 2.391378] raid6: int64x2 xor() 591 MB/s
[ 2.459492] raid6: int64x1 gen() 449 MB/s
[ 2.527527] raid6: int64x1 xor() 450 MB/s
[ 2.527564] raid6: using algorithm neonx8 gen() 1544 MB/s
[ 2.531523] raid6: .... xor() 1461 MB/s, rmw enabled
[ 2.536453] raid6: using neon recovery algorithm
[ 2.541426] iommu: Default domain type: Translated
[ 2.546094] SCSI subsystem initialized
[ 2.549743] usbcore: registered new interface driver usbfs
[ 2.555080] usbcore: registered new interface driver hub
[ 2.560354] usbcore: registered new device driver usb
[ 2.565392] mc: Linux media interface: v0.10
[ 2.569603] videodev: Linux video capture interface: v2.00
[ 2.575054] pps_core: LinuxPPS API ver. 1 registered
[ 2.579968] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.589061] PTP clock support registered
[ 2.592954] EDAC MC: Ver: 3.0.0
[ 2.596436] zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
[ 2.604713] FPGA manager framework
[ 2.608038] Advanced Linux Sound Architecture Driver Initialized.
[ 2.614228] Bluetooth: Core ver 2.22
[ 2.617528] NET: Registered protocol family 31
[ 2.621926] Bluetooth: HCI device and connection manager initialized
[ 2.628243] Bluetooth: HCI socket layer initialized
[ 2.633086] Bluetooth: L2CAP socket layer initialized
[ 2.638109] Bluetooth: SCO socket layer initialized
[ 2.643260] clocksource: Switched to clocksource arch_sys_counter
[ 2.649112] VFS: Disk quotas dquot_6.6.0
[ 2.652936] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.663751] NET: Registered protocol family 2
[ 2.664381] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 2.672577] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 2.680607] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 2.688062] TCP: Hash tables configured (established 32768 bind 32768)
[ 2.694226] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.700892] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 2.708073] NET: Registered protocol family 1
[ 2.712510] RPC: Registered named UNIX socket transport module.
[ 2.718129] RPC: Registered udp transport module.
[ 2.722800] RPC: Registered tcp transport module.
[ 2.727468] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.734103] PCI: CLS 0 bytes, default 64
[ 2.737860] Trying to unpack rootfs image as initramfs...
[ 7.121980] Freeing initrd memory: 90336K
[ 7.122445] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 7.127628] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 7.136072] Initialise system trusted keyrings
[ 7.139691] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 7.146761] NFS: Registering the id_resolver key type
[ 7.150994] Key type id_resolver registered
[ 7.155135] Key type id_legacy registered
[ 7.159120] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 7.165790] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[ 7.186814] NET: Registered protocol family 38
[ 7.186857] Key type asymmetric registered
[ 7.189692] Asymmetric key parser 'x509' registered
[ 7.194552] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 7.201886] io scheduler mq-deadline registered
[ 7.206384] io scheduler kyber registered
[ 7.212384] xilinx-frmbuf a00f0000.v_frmbuf_rd: Unable to locate reset property in dt
[ 7.218156] xilinx-frmbuf: probe of a00f0000.v_frmbuf_rd failed with error -2
[ 7.225282] xilinx-frmbuf a0200000.v_frmbuf_wr: Unable to locate reset property in dt
[ 7.233033] xilinx-frmbuf: probe of a0200000.v_frmbuf_wr failed with error -2
[ 7.264211] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 7.268465] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 7.275207] brd: module loaded
[ 7.279674] loop: module loaded
[ 7.280508] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 7.284692] libphy: Fixed MDIO Bus: probed
[ 7.288605] tun: Universal TUN/TAP device driver, 1.6
[ 7.292741] CAN device driver interface
[ 7.297347] usbcore: registered new interface driver asix
[ 7.301876] usbcore: registered new interface driver ax88179_178a
[ 7.307912] usbcore: registered new interface driver cdc_ether
[ 7.313706] usbcore: registered new interface driver net1080
[ 7.319331] usbcore: registered new interface driver cdc_subset
[ 7.325213] usbcore: registered new interface driver zaurus
[ 7.330759] usbcore: registered new interface driver cdc_ncm
[ 7.337139] usbcore: registered new interface driver uas
[ 7.341659] usbcore: registered new interface driver usb-storage
[ 7.348166] rtc_zynqmp ffa60000.rtc: registered as rtc0
[ 7.352849] i2c /dev entries driver
[ 7.357968] usbcore: registered new interface driver uvcvideo
[ 7.361960] USB Video Class driver (1.1.1)
[ 7.366985] Bluetooth: HCI UART driver ver 2.3
[ 7.370442] Bluetooth: HCI UART protocol H4 registered
[ 7.375543] Bluetooth: HCI UART protocol BCSP registered
[ 7.380835] Bluetooth: HCI UART protocol LL registered
[ 7.385924] Bluetooth: HCI UART protocol ATH3K registered
[ 7.391299] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 7.397554] Bluetooth: HCI UART protocol Intel registered
[ 7.402892] Bluetooth: HCI UART protocol QCA registered
[ 7.408092] usbcore: registered new interface driver bcm203x
[ 7.413717] usbcore: registered new interface driver bpa10x
[ 7.419260] usbcore: registered new interface driver bfusb
[ 7.424701] usbcore: registered new interface driver btusb
[ 7.430165] usbcore: registered new interface driver ath3k
[ 7.435690] EDAC MC: ECC not enabled
[ 7.439282] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 7.451653] sdhci: Secure Digital Host Controller Interface driver
[ 7.457381] sdhci: Copyright(c) Pierre Ossman
[ 7.461703] sdhci-pltfm: SDHCI platform and OF driver helper
[ 7.467691] ledtrig-cpu: registered to indicate activity on CPUs
[ 7.473339] zynqmp_firmware_probe Platform Management API v1.1
[ 7.479095] zynqmp_firmware_probe Trustzone version v1.0
[ 7.487544] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[ 7.515977] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[ 7.517880] zynqmp_aes zynqmp_aes: AES Successfully Registered
[ 7.517880]
[ 7.523494] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 7.531177] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 7.536688] usbcore: registered new interface driver usbhid
[ 7.540483] usbhid: USB HID core driver
[ 7.546696] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 7.551018] usbcore: registered new interface driver snd-usb-audio
[ 7.557735] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 7.564898] Initializing XFRM netlink socket
[ 7.568680] NET: Registered protocol family 10
[ 7.573407] Segment Routing with IPv6
[ 7.576752] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 7.582850] NET: Registered protocol family 17
[ 7.586947] NET: Registered protocol family 15
[ 7.591364] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 7.604236] can: controller area network core (rev 20170425 abi 9)
[ 7.610398] NET: Registered protocol family 29
[ 7.614791] can: raw protocol (rev 20170425)
[ 7.619028] can: broadcast manager protocol (rev 20170425 t)
[ 7.624654] can: netlink gateway (rev 20190810) max_hops=1
[ 7.630191] Bluetooth: RFCOMM TTY layer initialized
[ 7.634953] Bluetooth: RFCOMM socket layer initialized
[ 7.640062] Bluetooth: RFCOMM ver 1.11
[ 7.643776] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.649046] Bluetooth: BNEP filters: protocol multicast
[ 7.654240] Bluetooth: BNEP socket layer initialized
[ 7.659168] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 7.665052] Bluetooth: HIDP socket layer initialized
[ 7.670105] 9pnet: Installing 9P2000 support
[ 7.674243] Key type dns_resolver registered
[ 7.678727] registered taskstats version 1
[ 7.682529] Loading compiled-in X.509 certificates
[ 7.687668] Btrfs loaded, crc32c=crc32c-generic
[ 7.700709] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 42, base_baud = 6249375) is a xuartps
[ 7.709727] printk: console [ttyPS0] enabled
[ 7.714023] printk: bootconsole [cdns0] disabled
[ 7.723522] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 43, base_baud = 6249375) is a xuartps
[ 7.736757] of-fpga-region fpga-full: FPGA Region probed
[ 7.743786] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[ 7.750354] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 7.757456] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 7.764577] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 7.771672] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 7.778774] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 7.785878] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 7.792978] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 7.800079] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 7.807256] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[ 7.814355] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[ 7.821461] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[ 7.828559] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[ 7.835661] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[ 7.842759] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[ 7.849861] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[ 7.856962] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[ 7.864267] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[ 7.875266] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[ 7.885930] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[ 7.893960] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[ 7.902454] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 7.914882] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 7.927583] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[ 7.937748] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[ 7.944731] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 7.951336] [drm] No driver support for vblank timestamp query.
[ 7.957311] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffffc010ca7138)
[ 9.043276] [drm] Cannot find any crtc or sizes
[ 9.048054] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[ 9.056163] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[ 9.064953] ahci-ceva fd0c0000.ahci: fd0c0000.ahci supply ahci not found, using dummy regulator
[ 9.073673] ahci-ceva fd0c0000.ahci: fd0c0000.ahci supply phy not found, using dummy regulator
[ 9.082320] ahci-ceva fd0c0000.ahci: fd0c0000.ahci supply target not found, using dummy regulator
[ 9.091344] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[ 9.109282] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 9.118241] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 9.128560] scsi host0: ahci-ceva
[ 9.132123] scsi host1: ahci-ceva
[ 9.135548] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 40
[ 9.143463] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 40
[ 9.151925] spi-nor spi0.0: found mt25qu512a (n25q512a), expected m25p80
[ 9.158964] spi-nor spi0.0: mt25qu512a (n25q512a) (131072 Kbytes)
[ 9.165069] 3 fixed-partitions partitions found on MTD device spi0.0
[ 9.171412] Creating 3 MTD partitions on "spi0.0":
[ 9.176198] 0x000000000000-0x000001e00000 : "boot"
[ 9.181767] 0x000001e00000-0x000001e40000 : "bootenv"
[ 9.187502] 0x000001e40000-0x000005a40000 : "kernel"
[ 9.195119] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 9.202440] libphy: MACB_mii_bus: probed
[ 9.209748] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[ 9.222788] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:00:22:01)
[ 9.232949] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 9.239493] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 9.245972] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 9.252447] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 9.260349] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[ 9.266132] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[ 9.276411] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 9.281908] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 9.289659] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[ 9.299072] xhci-hcd xhci-hcd.0.auto: irq 52, io mem 0xfe200000
[ 9.305198] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 9.313464] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.320681] usb usb1: Product: xHCI Host Controller
[ 9.325551] usb usb1: Manufacturer: Linux 5.4.0-xilinx-v2020.1 xhci-hcd
[ 9.332156] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 9.337301] hub 1-0:1.0: USB hub found
[ 9.341070] hub 1-0:1.0: 1 port detected
[ 9.345171] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 9.350655] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 9.358311] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 9.365049] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 9.373308] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.380527] usb usb2: Product: xHCI Host Controller
[ 9.385396] usb usb2: Manufacturer: Linux 5.4.0-xilinx-v2020.1 xhci-hcd
[ 9.392003] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 9.397106] hub 2-0:1.0: USB hub found
[ 9.400868] hub 2-0:1.0: 1 port detected
[ 9.405837] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
[ 9.413761] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator
[ 9.429418] i2c i2c-0: Added multiplexed i2c bus 3
[ 9.440270] i2c i2c-0: Added multiplexed i2c bus 4
[ 9.457116] random: fast init done
[ 9.465471] ata1: SATA link down (SStatus 0 SControl 330)
[ 9.470886] ata2: SATA link down (SStatus 0 SControl 330)
[ 9.497190] i2c i2c-0: Added multiplexed i2c bus 5
[ 9.502103] i2c i2c-0: Added multiplexed i2c bus 6
[ 9.506892] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[ 9.514220] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[ 9.521929] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 9.528651] i2c i2c-1: Added multiplexed i2c bus 7
[ 9.533630] i2c i2c-1: Added multiplexed i2c bus 8
[ 9.541104] si570 9-005d: registered, current frequency 300000000 Hz
[ 9.547483] i2c i2c-1: Added multiplexed i2c bus 9
[ 9.567048] si570 10-005d: registered, current frequency 148500000 Hz
[ 9.573515] i2c i2c-1: Added multiplexed i2c bus 10
[ 9.578584] si5324 11-0069: si5328 probed
[ 9.641005] si5324 11-0069: si5328 probe successful
[ 9.645903] i2c i2c-1: Added multiplexed i2c bus 11
[ 9.650963] i2c i2c-1: Added multiplexed i2c bus 12
[ 9.655955] i2c i2c-1: Added multiplexed i2c bus 13
[ 9.660944] i2c i2c-1: Added multiplexed i2c bus 14
[ 9.665821] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[ 9.673718] i2c i2c-1: Added multiplexed i2c bus 15
[ 9.678717] i2c i2c-1: Added multiplexed i2c bus 16
[ 9.683702] i2c i2c-1: Added multiplexed i2c bus 17
[ 9.689038] i2c i2c-1: Added multiplexed i2c bus 18
[ 9.694029] i2c i2c-1: Added multiplexed i2c bus 19
[ 9.699022] i2c i2c-1: Added multiplexed i2c bus 20
[ 9.704017] i2c i2c-1: Added multiplexed i2c bus 21
[ 9.709010] i2c i2c-1: Added multiplexed i2c bus 22
[ 9.713885] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[ 9.721472] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[ 9.731090] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[ 9.738542] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer with timeout 10s
[ 9.746135] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1199880 KHz
[ 9.753580] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[ 9.794769] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[ 9.805284] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 9.812388] rtc_zynqmp ffa60000.rtc: setting system clock to 2020-07-02T12:00:20 UTC (1593691220)
[ 9.821266] of_cfs_init
[ 9.823721] of_cfs_init: OK
[ 9.826653] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.875042] mmc0: new high speed SDHC card at address aaaa
[ 9.880962] mmcblk0: mmc0:aaaa SB16G 14.8 GiB
[ 9.890649] mmcblk0: p1 p2
[ 9.968238] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 9.974768] clk: Not disabling unused clocks
[ 9.979029] ALSA device list:
[ 9.981989] #0: DisplayPort monitor
[ 9.985934] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 9.994546] cfg80211: failed to load regulatory.db
[ 9.999534] Freeing unused kernel memory: 704K
[ 10.019291] Run /init as init process
INIT: version 2.88 booting
Starting udev
[ 10.120924] udevd[167]: starting version 3.2.8
[ 10.125684] random: udevd: uninitialized urandom read (16 bytes read)
[ 10.132184] random: udevd: uninitialized urandom read (16 bytes read)
[ 10.138693] random: udevd: uninitialized urandom read (16 bytes read)
[ 10.150273] udevd[168]: starting eudev-3.2.8
[ 10.167297] [drm] Cannot find any crtc or sizes
[ 10.213658] mali: loading out-of-tree module taints kernel.
[ 10.523195] xilinx-vcu xilinx-vcu: Could not get core_enc clock
[ 10.530163] VCU PLL: enable
[ 10.533692] xilinx-vcu xilinx-vcu: xvcu_probe: Probed successfully
[ 10.558254] al5d a0120000.al5d: l2 prefetch size:17530880 (bits), l2 color bitdepth:10
[ 10.559920] al5e a0100000.al5e: l2 prefetch size:17530880 (bits), l2 color bitdepth:10
[ 10.626619] EXT4-fs (mmcblk0p2): recovery complete
[ 10.632227] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.633354] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
Running postinst /etc/rpm-postinsts/101-libmali-xlnx...
[ 10.999089] update-alternatives: Linking /usr/lib/libMali.so.9.0 to /usr/lib/x11/libMali.so.9.0
[ 11.039489] update-alternatives: Linking /usr/lib/libMali.so.9.0 to /usr/lib/x11/libMali.so.9.0
[ 11.068396] Warn: update-alternatives: libmali-xlnx has multiple providers with the same priority, please check /usr/lib/opkg/alternatives/libmali-xlnx for details
[ 11.094821] update-alternatives: Linking /usr/lib/libMali.so.9.0 to /usr/lib/x11/libMali.so.9.0
[ 11.134819] update-alternatives: Linking /usr/lib/libMali.so.9.0 to /usr/lib/x11/libMali.so.9.0
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
INIT: Entering runlevel: 5
Configuring network interfaces... [ 11.215221] macb ff0e0000.ethernet eth0: link up (100/Full)
[ 11.220974] pps pps0: new PPS source ptp0
[ 11.224992] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[ 11.231734] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
udhcpc: started, v1.31.0
udhcpc: sending discover
udhcpc: no lease, forking to background
done.
Starting system message bus: dbus.
Starting haveged: haveged: listening socket at 3
haveged: haveged starting up
Attempting to run my GStreamer pipeline fails as follows.
gst-launch-1.0 videotestsrc ! videoconvert ! fpsdisplaysink name=fpssink text-overlay=false video-sink="kmssink bus-id="a0070000.v_mix" fullscreen-overlay=1"
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpssink/GstKMSSink:kmssink0: Could not open DRM module (NULL)
Additional debug info:
../../../git/sys/kms/gstkmssink.c(1039): gst_kms_sink_start (): /GstPipeline:pipeline0/GstFPSDisplaySink:fpssink/GstKMSSink:kmssink0:
reason: No such device (19)
Setting pipeline to NULL ...
Freeing pipeline ...
Hint : In my kernel logs,hdmi is not defined.Should I change config of device tree blob? If your answer is yes, how can I do that?
Any advices?
Tags (2)
HI @hakann
I do not think the design from the pre-built image includes the HDMI TX subsystem which is required for the HDMI output so you will probably not be able to use the HDMI output with it.
You can potentially use some images from the VCU TRD:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/541786440/Zynq+UltraScale+MPSoC+VCU+TRD+2020.1+-+HDMI+Video+Display
Florent
HI @hakann
Florent
It is worked. Thank you so much!
