trenz-al
ZCU102, Display RX example, BAD C code ? Or error in PG233 ?
Xilinx Product Guide PG233, Page 25, Table 2-6, Offset 4, Bits [15:8] Allowable values: 8,16,24,32,40,48
But the EXAMPLE Code generated by Vivado 2017.4 initializes those bits [15:8] with 0 (0x00 all Zero bits) - So either the PG233 info is wrong, or the Example code is wrong?
florentw
Hi @trenz-al,
The example design is working showing that it is working with 0 ;)
Yes, there might be cases where it is required to be non-zero. It will depends on your AXI4-Lite clock frequency to be in the correct range
Florent
florentw
Hi @trenz-al,
Yes it does not seems to be set in the example design. Let me clarify that and come back to you
Florent
florentw
Hi @trenz-al,
0 is the default value so it is missing in the PG233 (and PG300). This will be added in the next version of the PG.
Florent
trenz-al
Does it mean that it can be safely left at 0?
It has no negative Impact and everything should just work if we use the Default 0 value?
Or do cases exist where it is needed to be non-Zero ?
florentw
Hi @trenz-al,
Florent
florentw
HI @trenz-al,
Is the answer is clear for you?
Florent
