teampro1
ZCU104 VCU examples error: failed to configure video mode
Currently I'm trying to start the VCU examples on the ZCU104. I use the prebuild peta-linux image (2018.2, also tried the 2018.1 version) and use this document https://www.xilinx.com/support/documentation/ip_documentation/vcu/v1_1/pg252-vcu.pdf (chapter 11) to  set everything in place. The vcu-demo-camera-encode-decode-display.sh -s 640x480 works, as well as vcu-demo-transcode-to-file.sh but unfortunately all the other examples won't work.
I also used several gst-launch commands, that didn't work as well. Everything seems to be pointing at the kmssink not being able to configure the video mode (picture 1). But when I use the kmssink force-modesetting=1 it displays different errors (picture 2).
Hardware setup:
zcu104 dp to dp monitor
usb econ see3cam
ethernet cable to the router
I hope this question wasn't already asked (I looked around for a bit but couldn't find anything) and I hope someone can help me.
Greetings!
florentw
Hi @teampro1,
I am getting the same error as you do if there is no monitor detected.
What is the maximum supported resolution of your DP monitor? Do it support 2160p?
florentw
Hi @teampro1,
> So you mean that for example vcu-demo-decode-display.sh is not working? What file did you try? Could you please share the log for this one?
I will try on my board tomorrow and we can then compare.
teampro1
@florentw indeed the other examples don't work, for example when I try the vcu-demo-decode-display.sh -i /home/root/bbb_sunflower_2160p_30fps_normal_avc.mp4 -c avc -a aac it displays the "kmssink: failed to configure video mode".  This error I get for all the other examples as well (just not for the transcode file and camara encode-decode example). The video is the bbb_sunflower_2160p_30fps_normal_avc.mp4 which is transmitted fine to the board (after using the vcu-demo-decode-display.sh script the video is present in the /home/root/ folder).
I attached the debug info of the error I get when trying the example. I don't know if you meant that by sharing the log, if not could you provide information on how to get the log?
Thank you for replying!
root@xilinx-zcu104-2018_2:/# gst-launch-1.0 --gst-debug=1 filesrc location=/home/root/bbb_sunflower_2160p_30fps_normal_avc.mp4 ! qtdemux name=demux demux.video_0 ! h264parse ! omxh264dec ! queue max-size-bytes=0 ! kmssink bus-id=fd4a0000.zynqmp-display fullscreen-overlay=1
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
0:00:00.531608200  2927     0x2fe02590 ERROR                kmssink gstkmssink.c:559:configure_mode_setting:<kmssink0> cannot find appropriate mode
ERROR: from element /GstPipeline:pipeline0/GstKMSSink:kmssink0: GStreamer error: negotiation problem.
Additional debug info:
../../../git/sys/kms/gstkmssink.c(1218): gst_kms_sink_set_caps (): /GstPipeline:pipeline0/GstKMSSink:kmssink0:
Execution ended after 0:00:00.208137676
0:00:00.581835039  2927     0x2fe02590 ERROR                kmssink gstkmssink.c:559:configure_mode_setting:<kmssink0> cannot find appropriate mode
Setting pipeline to READY ...
0:00:00.972876182  2927   0x7f88008d90 ERROR                    omx gstomx.c:2360:gst_omx_port_populate_unlocked:<omxh264dec-omxh264dec0> Populated decoder port 1: Incorrect state operation (0x80001018)
Setting pipeline to NULL ...
Freeing pipeline ...
p.s I toke the generated gst-launch1.0 command out of the vcu-demo-decode-display.sh example so that I could add the gst-debug for more info.
florentw
Hi @teampro1,
teampro1
My monitor is a Dell U2715H which indeed doesn't support 2160p (it supports a maximum resolution of 2560x1440). I tried the vcu-demo-decode-display.sh with a different file (720p) and everything seems to be working well. Feeling kinda dumb right now but thank you very much for helping me!
florentw
Hi @teampro1,
Good to know that it is working now.
No problem, the error from GStreamer are never easy to read ;).
