bjnew
ZCU104 board: No HDMI TX data pin definition in auto-generated HDMI example contraints file
I am now trying to run HDMI TX example on ZCU104 board.
I follow the guide of pg235-v-hdmi-tx-ss.pdf to generated the example code in Vivado 2018.2, and the generated contraints file v_hdmi_tx_ss_0_ex/imports/hdmi_example_zcu104.xdc is as following.
Could anyone tell me why there is not  HDMI TX data pins' definition in this constraints file?
## Constraints for ZCU104 FMC HDMI 2.0
## Version 1.0
## Pins
# TBD
set_property PACKAGE_PIN M11 [get_ports reset]
set_property IOSTANDARD LVCMOS33 [get_ports reset]
# HDMI TX
set_property PACKAGE_PIN T8 [get_ports TX_REFCLK_P_IN]
# rev B
set_property PACKAGE_PIN G21 [get_ports {HDMI_TX_CLK_P_OUT}]
set_property IOSTANDARD LVDS [get_ports {HDMI_TX_CLK_P_OUT}]
# TBD
# set_property PACKAGE_PIN G8 [get_ports tmds_clk_out]
# set_property IOSTANDARD LVCMOS33 [get_ports tmds_clk_out]
set_property PACKAGE_PIN E3 [get_ports TX_HPD_IN]
set_property IOSTANDARD LVCMOS33 [get_ports TX_HPD_IN]
set_property PACKAGE_PIN B1 [get_ports TX_DDC_OUT_scl_io]
set_property IOSTANDARD LVCMOS33 [get_ports TX_DDC_OUT_scl_io]
set_property PACKAGE_PIN C1 [get_ports TX_DDC_OUT_sda_io]
set_property IOSTANDARD LVCMOS33 [get_ports TX_DDC_OUT_sda_io]
# I2C
set_property IOSTANDARD LVCMOS33 [get_ports fmch_iic_scl_io]
set_property PACKAGE_PIN D1 [get_ports fmch_iic_scl_io]
set_property IOSTANDARD LVCMOS33 [get_ports fmch_iic_sda_io]
set_property PACKAGE_PIN E1 [get_ports fmch_iic_sda_io]
# Misc
#GPIO_LED_0_LS
set_property PACKAGE_PIN D5 [get_ports LED0]
set_property IOSTANDARD LVCMOS33 [get_ports {LED0}]
set_property PACKAGE_PIN M12 [get_ports IDT_8T49N241_RST_OUT]
set_property IOSTANDARD LVCMOS33 [get_ports IDT_8T49N241_RST_OUT]
set_property PACKAGE_PIN N11 [get_ports IDT_8T49N241_LOL_IN]
set_property IOSTANDARD LVCMOS33 [get_ports IDT_8T49N241_LOL_IN]
set_property PACKAGE_PIN A2 [get_ports TX_EN_OUT]
set_property IOSTANDARD LVCMOS33 [get_ports TX_EN_OUT]
# TBD - not needed as it is duplicated of TX_EN_OUT
# set_property PACKAGE_PIN C2 [get_ports {RX_LS_OE[0]}]
# set_property IOSTANDARD LVCMOS33 [get_ports {RX_LS_OE[0]}]
## End
xud
@bjnew
If you don't have more questions related to this, can you close this thread by marking  accept solution please?
xud
@bjnew
Once GT Channel Location is selected in Video PHY GUI, the txp/n are fixed. The GT Channel LOC constraint is generated with Video PHY.
The screenshot below shows how to find scoped constraint file, which contains GT channel LOC constraint.
bjnew
Get it ,thanks a lot!
xud
@bjnew
