ZCU106 HD SDI Interface capability
Does the Zynq UltraScale+ MPSoC ZCU106 Evaluation Kit support 3G-SDI on the HD SDI Video Interface?
Tags (4)
HI @sommerj
To add to @watari
The ZCU106 can support up to 12G-SDI (ie. it can support SD/HD/3G/6G and 12G-SDI) using the UHD-SDI TX / RX subsystem IP
Hi @sommerj
Yes.
Refer the following URL, if you want to get example design.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/541786287/Zynq+UltraScale+MPSoC+VCU+TRD+2020.1+-+SDI+Video+Capture+and+SDI+Display+with+PLDDR
Hope it helps.
Thank you @watari this helps answer my question
HI @sommerj
To add to @watari
Thank you @florentw that fully answers my question.
