oktayogutcu
ZYNQ Video Stream: SD Card to HDMI by AXI VDMA
I've an issue on video application with zynq ZC702.I want to display and process video stream(.bin images) that read from SD card. I used Triple Buffer mode of VDMA, to all buffers i sent the same frame, but i've problems with display. Some regions are displayed wrong. Then i enabled interrupts of VDMA to know Read Done or not, after Read Done interrupt i sent new frame(.bin) from SD Card, but it doesnt fix my problem.
Questions,
1) If there is, should i use single buffer mode?
2) Is my approach can be applicated on this system(SD Card - VDMA Read Port) ?
3) How can i built this system with true timings?
oktayogutcu
oktayogutcu
As s patial solution, i read images initally and then gave them one by one to vdma read port. So i just wait at start. But changing storage device ord slowing down the pixel clock might be exact solution.
watari
Hi @oktayogutcu
How do you deal with these signals ?
- mm2s_fsync
- s2mm_fsync
- mm2s_frame_ptr_in
- s2mm_frame_ptr_in
Best regards,
oktayogutcu
I'm using vtc and video out ips. I generate proper sync signals according to my resolution with vtc. The problem is, I don't know how to met with that timing with reading images from sd card. If it is slow i can generate slower timings from the vtc. I don't know what to do exactly.
By the way, I'm reading images from ps to ddr2 memory, so I'm just using mm2s port.
watari
Hi @oktayogutcu
I don't know your target resolution.
But it's relevant to your target resolution issue or low speed issue for SD card.
I suggest you to change storage device from SD card to other high speed device.
Or change resolution to more smaller.
Best regards,
oktayogutcu
