tim_severance
Zynq US+ DP 1.4 TX design low power thermal
I am working on a Zynq US+ (4CG) design for DP 1.4 TX only which will be used in a production test environment where test time is very important.   We are having concerns about how hot the FPGA is going to get in our design and I am wondering if there is an idle state I can put the design into when it is not being used and if so how quickly it can be woken up.   Also, if there is a low power state that you recommend, is there a way to determine how much cooler the FPGA would be in that state?
Does somebody know of a low power mode state for the DP 1.4 TX design?
Tim
watari
Hi @tim_severance
How about disabling Main Link to go to a low power mode ?
https://www.xilinx.com/support/documentation/ip_documentation/v_dp_txss1/v3_0/pg299-v-dp-txss1.pdf#page=41
Best regards,
