daveA
Zynq UltraScale+ MPSoC VCU TRD 2019.1 (ZCU106)
I have just downloaded the TRD (rdf0428-zcu106-vcu-trd-2019-1_v2) and the dtsi files appear to be missing. Can someone please point me in the right direction?
Dave
daveA
You are correct Florent - they are generated in that location after created the project from the bsp.
Many thanks,
Dave
florentw
HI @daveA
Are they not under project-spec/meta-user/recipes-bsp/device-tree/files/ when you create a new petalinux project using the BSP provided in the VCU package as source?
Florent
florentw
Hi @daveA
Is everything clear for you on this topic? If yes, could you kindly mark the correct reply as accepted solution to close the thread?
Thanks and Regards
Florent
daveA
Many thanks,
Dave
