RingZero
Zynq Ultrascale+ MPSoC DP Controller training issues
Hello everyone
I'm working with the DisplayPort controller inside a Zynq Ultrascale+ MPSoC. I have been able to get a live video output working correctly on a prototyping board with a native DisplayPort connector and a single lane. I started with the DPDMA example, eventually removing the DMA flow and instead using a live native video interface from the PL.
However, when porting the design to the final platform, which instead has a TI USB-C DisplayPort alternate mode output pipeline and up to two lanes, I am experiencing some issues. When I have two lanes enabled, the application continuously reports successful training, followed by an HPD pulse that initiates retraining, never showing anything on the screen.
However, if I pause the application (through the SDK debugging tools), or if I turn off the monitor from its power button, I will eventually get an output (when I turn the monitor back on, or after some period of the application being paused). Unfortunately, the stream seems unstable. The display periodically shuts on and off, with no indication of any activity from the application (no HPD activity).
It appears to behave better with a single lane enabled; the monitor does not continuously send HPD pulses, but the issue with the display remains.
Has such an operation pattern been observed by anyone here? It's difficult for me to debug this issue.
Thanks!
bpatil
Hi @RingZero
Kindly go through following forum post by @florentw
https://forums.xilinx.com/t5/Video-and-Audio/Ultrascale-Display-Port-over-USB-C-interface/td-p/1109611
https://forums.xilinx.com/t5/Video-and-Audio/DisplayPort-to-USB-C-in-Ultra96-board/td-p/1112448
Bhushan
watari
Hi @RingZero
Did you make sure DPCD value ?
What is your target monitor ?
What is your target resolution and vertical frequency ?
Share USB device and structure, if possible.
Nobody reply it without detail information.
Because it depends on them.
Best regards,
RingZero
The monitor is an Asus VE248 1920x1080 monitor. According to the DPCD it supports up to 2 lanes and HBR (2.7Gbps).
I have tested the application with both 1024x768 at 60Hz and 1280x720 at 60Hz resolutions. Our test pattern generator module doesn't produce front or back porches, only sync signals. These are the exact video modes and pixel clocks:
Both of these modes are at a 60Hz vertical refresh.
1024x768 mode (pixel clock = 1520 MHz/27; 56.296 MHz):
Active: 1024 (H) 768 (V)
Front porch: 0 (H)  0 (V)
Sync width: 160 (H) 24 (V)
Back porch: 0 (H) 0 (V)
Total: 1184 (H) 792 (V)
Sync polarity: 0 (H) 0 (V)
1280x720 mode (pixel clock = 1520 MHz/23; 66.086 MHz):
Active: 1280 (H) 720 (V)
FrontP: 0 (H) 0 (V)
SyncW: 206 (H) 21 (V)
BackP: 0 (H) 0 (V)
Total: 1486 (H) 741 (V)
Polarity: 0 (H) 0 (V)
The USB PD controller is a Texas Instruments TPS65981, and the USB-C high-speed lanes are output through a TUSB1046AI-DCIRNQR alternate mode redriver. The redriver is configured for 4 DisplayPort lanes. An off-the-shelf USB-C hub provides a native DisplayPort output. The hub supports DP alternate mode pin configuration C.
bpatil
Hi @RingZero
Bhushan
