ZynqMP displayport monitor detection
Is there a register  on the ZynqMP that show the status of the DP Hot Detect line? or in general if a monitor is connected to the Displayport at zynqmp_dpsub: zynqmp-display@fd4a0000?
I need to know if anything is connected prior to attempting to start up a gstreamer pipeline to the kmssink.
aoifem
Hi matthew.singer@elbitsystems-us.com
If this issue is resolved, can you mark the appropriate post as 'accepted solution'?
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
florentw
There is an interrupt which can be generated upon HDP detection. You will have a connect/disconnect event. Refer to the wiki page for the linux driver:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842105/ZynqMP+DisplayPort+Linux+driver
Thank you.  By reading thru the standalone driver, I found that I can monitor bit 0 of fd4a0130.
aoifem
Aoife
