mksafavi
how can I use AXIDMA on Gstreamer with a custom ip core?
we're designing an FPGA-based video processing system on Zynq ultrascale+.we have a (decoder+scaler+encoder) pipeline. the decoder and encoder are both from Xilinx IPcore (PG252).
I want to get the Decoder Output address and send it to the scaler unit and tell it to start. (scaler unit has three registers .one for informing it to start and two for the beginning of its input & output stream).In a test written in C, we did it by getting the address of output data and directly wring it on DMA registers to inform the scaler unit.
How can I do the same thing with Gstreamer?
_____________________________________
mksafavi [at] avanco.tech
florentw
HI @mksafavi
Why are you using the AXI DMA and not the AXI VDMA which is an Video DMA? This would keep the video information (Start of frame / End of Line), while the AXI DMA has no notion about this. Thus I am not sure if you can intergate it into a V4L2 pipeline and so I am not sure if you can use it with Gstreamer.
And even more, why aren't you using the Video frame buffer read and write as used in the VCU TRD for example? It is better because it can store video data in memory following the V4L2 video format.
Then, if you want to use your custom IP, it needs to have a V4L2 (or DRM) driver (supporting memory to memory) which can be integrated in the pipe in order for Gstreamer to use it.
Why aren't you using the Xilinx multi-sclaer IP or the Video Processing Subsystem? They have already the required drivers.
florentw
HI @mksafavi
mksafavi
hi. thanks for your answer.
We're using Xilinx VCU and our videos are digital (stored in one location with 4:2:0 format). So we think we don't need to use AXI-VDMA. (also, in the Xilinx VCU design example AXI-VDMA wasn't used.)
in tests, our scaler proved to be faster then Xilinx multi-scaler and the scaler in VPSS.
florentw
HI @mksafavi
The VCU example design does not use an AXI VDMA but is also not using an AXI DMA...
It is using the Video Frame Buffer Read/Right to store/read frames from the memory. My point is the same, I am not sure it will work in Gstreamer with the AXI DMA.
> I am not saying that the Xilinx VPSS or multiscaler is the best in class but at least the drivers are available, so it speed up development time.
PS. I am not sure what you mean by faster. The VPSS and Multiscaler IPs can support up to 8K so are able to run fast enough for these rate. And for the latency, this is based on the scaler window. There is no way you can really do better (note that you could reduce the processing window in both IPs). When I am saying that the IPs are not the best in class is that you could find IPs with better algorithm (newer algo) or using less ressources. But the quality is usually enough for most of our customers.
samk
Hi @mksafavi,
Is everything clear for you on this topic?
If your question is answered or your issue is solved, please kindly mark the response which helped find a solution (click on "Accept as solution" button below the reply)
If this is not solved/answered, please reply to the thread giving more information on your current status.
Thanks and Regards,
Sam
Xilinx Video Design Hub
