pls help me, why my display did not have any value come out?
no matter what i change the value of the pulse generator, the display still 0
it did not have any value come out
between the two pulse generator, there is quarter difference between it.
You might want to look at the results after the Gateway in.  You may be quatizing your signal at that point.
Chris
Versal ACAP: AI Engines | Embedded SW Support
