8T49N241 init failed in zcu104 csi rx project
I want to migrate the CSI-2 RX subsystem example design to my ZCU104 FPGA board and i found the reason that xmipi_example program didn't work might be the clock generator is 8T49N241 on zcu104 not the Si5324 on zcu102. So I modified the xmipi_example.c file. But the program displayed messages as follow
the xmipi project can be found in the attachment
Re: 8T49N241 init failed in zcu104 csi rx project
Hi @ivanfan
According to the following topic, it seems that you have solve your issue:
https://forums.xilinx.com/t5/Video/iic-send-data-failed-in-csi-rx-example/m-p/1019833#M27555
Could you kindly share your solution with the community as others might face the same?
Hello @ivanfan
Actually , I am not familiar with this IIC IP.
Are you sure that you are setting the correct ID ?
https://forums.xilinx.com/t5/Embedded-Development-Tools/I2C-xps-IIC-does-not-sending-data/td-p/47651
Hope this helps.
