Visitor potatopen688
AXI traffic generator to configure Video DMA
The Video DMA configuration address width S_AXI_LITE  is 8 bit
However, the Traffic Gnerator writing address is 32 bit
How to connect both of these buses for proper VDMA config?
Tags (2)
Re: AXI traffic generator to configure Video DMA
Hi @potatopen688,
You can use an AXI interconnect between the 2 IPs which will do the interfacing
Florent
Hi @potatopen688,
Florent
Hi @potatopen688,
Do you have any updates on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
