Anybody using buildroot ?
It's a bit offtopic for the EDK forum, but us there anybody using buildroot on Xilinx products ? It 'should' be as easy as 'make menuconfig && make' but obviously it doesn't work for me. I can compile the toolchain, busybox and other things, the the kernel fails during the final linking stage:
CC lib/vsprintf.o AR lib/lib.a GEN .version CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o LD init/built-in.o LD .tmp_vmlinux1 `.exit.data' referenced in section `.exit.text' of drivers/built-in.o: defined in discarded section `.exit.data' of drivers/built-in.o `.exit.data' referenced in section `.exit.text' of drivers/built-in.o: defined in discarded section `.exit.data' of drivers/built-in.o `.exit.data' referenced in section `.exit.text' of drivers/built-in.o: defined in discarded section `.exit.data' of drivers/built-in.o `.exit.data' referenced in section `.exit.text' of drivers/built-in.o: defined in discarded section `.exit.data' of drivers/built-in.o make[1]: *** [.tmp_vmlinux1] Error 1 make[1]: Leaving directory `/home/guinevere/buildroot/project_build_ppc/genepy/linux-2.6.24' make: *** [/home/guinevere/buildroot/binaries/genepy/-linux-2.6.24-20080318.z] Error 2
