C-PHY solution for FPGA
Hello guys.
I'm searching for any solution that could provide a C-PHY external interface for the VCU118 FPGA board. Ideally, it should be FMC board and since FPGA doesn't support C-PHY electrical interface directly, as I see it, I have two possibilities here:
1. D-PHY <-> C-PHY bridge(converter),
2. C-PHY chip with PPI interface that is connected to FPGA(not sure that this is feasible because of PPI parallel nature and relatively high frequency)
Maybe there are other ways to resolve the issue?!
Does Xilinx or Xilinx partner have the boards(or any solution) with similar functionality? Maybe someone has already run into this issue and could share the way it was resolved, any help will be helpful!
Tags (2)
Re: C-PHY solution for FPGA
Hello @egorman44
Unfortunately, for now Xilinx does not have any solution for C-PHY. (No IP solution, No FPGA pins that can natively support C-PHY)
I've never heard any C-PHY converter chip form our partner too.
I've seen two customers using Xilinx FPGA to receive MIPI C-PHY signal from sensors.
They are using discrete resistor network and they built their own IP. (Full custom board design)
Leo
Hello @egorman44
Leo
Hello Karnanl, thank you a lot for your reply. It looks like the custom board currently the only solution to provide a C-PHY external interface.
