Visitor gourav_123
Can't synthesize TPG videosystem
Hello ,
I m trying to implement TPG through zybo board for video streaming .I have installed TPG license.My design is validate correctly, but during synthesize it shown error that i listed below that.
  • [Synth 8-439] module 'design_1_v_tpg_0_0_v_tpg' not found
  • [Synth 8-285] failed synthesizing module 'design_1_v_tpg_0_0'
  • [Synth 8-285] failed synthesizing module 'design_1' .
I have checked previous thread on xilinx form
https://forums.xilinx.com/t5/Video/Can-t-synthesize-with-Video-Test-Pattern-Generator-even-with/td-p/683222
Still dosent get any idea how to resolve this.Pls provide some suggestions for that query
Thanks in advacne.
Re: Can't synthesize TPG videosystem
Hi @gourav_123,
Can you check the vivado_hls.log file created into the TPG IP output products (project.runs/synth_1/...tpg...) it should contain the error.
Possible reasons:
  1. You are under windows and the path is >256 characters
  2. You have an unexpected character in the project path (refer to AR#71759)
  3. Your license is not picked correctly
Also if you check the following post, Tim solved his issue by closing and re-openeing vivado:
https://forums.xilinx.com/t5/Video/VTPG-Synth-8-439-Module-not-found/m-p/884702
Florent
Hi @gourav_123,
Possible reasons:
Florent
