Chroma Resampler / Edge effect
I receive 3G SDI video, and convert it to RGB.
I use video to AXI 4 -> Chroma Resampler 422 to 444 -> YCbCr to RGB -> axi4 to video -> screen
Video is in black and white. But i add logo inscrustation in color.
When color change i have 2 pixels in other color (edge effect).
I attach a screenshot of signals in and out of chroma resampler.
We can see that it needs 2 clock cycles to out the good color value.
Anyone knows how to delete this effect?
Historian
Historian
Re: Chroma Resampler / Edge effect
What do you expect?
You are asking the tool to generate data to fill in the missing chroma values. The "Chroma Resampler" is clearly doing some kind of interpolation on the chroma channel in order to do this. This is a "feature" of the resampler - in a natural image this interpolation probably gives the best results.
However, if you want the "missing" chroma samples to be (for example) the chroma to the left, then just write a module that does this - replicate the existing chroma values into the missing ones.
I don't know the Chroma Resampler IP - maybe you can ask it to do simple replication rather than interpolation, but if not then you need to write the module yourself...
Avrum
Historian
Historian
What do you expect?
Avrum
@avrumw
I would like proper edge. For example, from black to red, without 2 green pixels between red and black.
Maybe it is impossible...
HI @pgrangeray,
As mentioned by @avrumw, you need to do your own IP. The Chroma Resampler IP is only a matrix. It does not have any notion of border, even more when the border are inside the image
Your case is a really complicated case as the boarder as inside the frame. It is not doable directly with the Chroma Resampler IP.
You might be able to do a block that find issues after the choma ressampler (if it find a boarder between BW and color then it redo the border). But I am not even sure that would give good result and this might use some logic ressources
Florent
Hi @florentw,
Ok, so it's more complicated than expected!
I will think about something, i don't know what but...
Thanks for all guys!
