Observer yuko.2828
Disable MIPI LP mode in CSI RX subsystem
Can we disable LP mode ?
PG232 does not have any explanation on it.
Thanks!
Re: Disable MIPI LP mode in CSI RX subsystem
Hello @yuko.2828
1. If you are using MIPI CSI-2 TX Subsystem IP,
You can set the Clock mode in Core configuration register. (see PG260 chapter 2 for more detailed information)
2. For MIPI CSI-2 RX Subsystem IP.
RX IP can receive both Continuous and Non-continuous clock mode, without any register setting modification required.
3. For reason (2), we do not mention this setting on PG232. (But MIPI D-PHY document (PG202) do mention that we support both Continuous/Non-continuous clock)
Hope this helps
Leo
Short answer: You cannot.
MIPI D-PHY specification introduces LP-mode (Low power mode) to suppress the power consumption during the blanking period ( or non-valid video data period ), LP mode is a must as defined in the specification.
Xilinx MIPI D-PHY/CSI-2 do support continuous clock mode (after initialization, clock lane will always toggling at HS mode), but this feature is only for clock-lane. Data lanes will do HS->LP transition after complete sending HS transmission.
Thanks & regards
Leo
Observer yuko.2828
Hi Leo,
Glad to know that Xilinx MIPI can receive HS input signal continously.
Thanks, I understand your explanation, I know what LP mode is.
But I think PG232 is not clear on it ?!
Hello @yuko.2828
Hope this helps
Leo
