DisplayPort AUX debug monitor IP Core, free use
as we ended up making an IP Core during ZU+ DisplayPort Debugging, well it is released as free IP core, if anyone has same needs.
http://www.trenz-electronic.de/de/download/d0/Trenz_Electronic/d1/ipcores/d2/2016.1.html
IP core is very simple, it requires 100mhz clock and should be connected to the DP AUX pins from ZU+ PS IP Block in Vivado, the decoded data is converted to AXI Stream. In our debug I connected ILA to this IP Core, set data qualifier to AXI TVALID, and then saved the data as CSV for offline decoding in Excel.
well I hope there is not so much need in such debugging, but if, then please use this IP core..
Re: DisplayPort AUX debug monitor IP Core, free use
Thanks for sharing!
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
Thanks for sharing!
Anirudh
