DisplayPort DPCD override
I'm looking for some example of DPCD override registers use (page 29, 30, 31, PG233). I want to force DP link to 2.7 Gbps and/or 2 lanes instead of 4, but I'm not sure when should I do this during IP core init. Should I just do it as soon as possible (beginning of init)?
Srdjan
Re: DisplayPort DPCD override
HI @srdjan.opacic
You can change the line rate in the Video PHY
Florent
Hi @srdjan.opacic
It might work but it is not the best solution. You might need to make sure that the driver is not re-writting the value based on the HW configuration (it might require to updated the drivers).
Is there a reason why you are not limiting the capabilities in the HW?
Florent
Hi @florentw ,
SW configuration seems more flexible, but if it is possible that driver will overwrite them, I'll use HW limitations instead. How can I force DP to work with maximum 2.7 Gbps? I see no such setting in Vivado IP configuration.
For reference, I'm using Vivado 2017.3.1, DP RX subsystem v2.1. DP port configuration 4x5.4Gbps lanes.
Srdjan
HI @srdjan.opacic
Florent
Sorry, forgot about that option.
Srdjan
