Observer furball
Displayport 1.4 example in vivado 2019.1
I use KCU105 platform and try to generate displayport 1.4 pass-through example in vivado 2019.1,
but it failed when generating ip output product, the error messages said that v_axi4s_remap ip are not found.
Then I add a IP repositories to ./Xilinx/Vivado/2019.1/data
but still can't solve it.
please help, thanks!
Re: Displayport 1.4 example in vivado 2019.1
Hi @furball
This is a quote of the guidelines for the video board on the Xilinx forums:
Before you post a question:
    Ensure you have read the Product Guide for the IP
    Search the Xilinx Knowledge Base for known issues.
    Search on the forums for similar topics
You might want to look for similar question before posting as it can save you some time.
The exact same question was asked last week:
https://forums.xilinx.com/t5/Video/Displayport1-4-MST-example-design-synthesis-failed/td-p/983285
This is probably due to the path length under windows
Hope that helps
Florent
Hi @furball
Hope that helps
Florent
Observer furball
sorry, i missed that post.
but i thought xilinx already fixed the windows path length issue since 2018.3.
HI @furball
Did you try to use a realy short path (i.e. build the example design on the root of your drive)? Xilinx only have reduced the length of the example design. The limitation is a windows limitation, thus Xilinx cannot fix it.
As per the AR:
Note: the path length of the example design project will be reduced in the 2018.3 release. The user will just need to select a short directory to build the example design into.
Florent
HI @furball
Did you try to reduce the path? I tried to open the example design on my windows machine, under C:/DP and it is working fine for me
Florent
