Error running xlBitstreamPostGeneration
Hello everybody,
it's since few days that when I try to generate a bistrem by the system generator appear this error:
Begin generation
Checking model status
Checking simulation times
Performing compilation and generation
Compilation and generation completed in 1.0568 seconds
*** ERROR ***
Java exception occurred:
com.xilinx.sysgen.netlist.NetlistInternal: java.io.FileNotFoundException: C:\Users\rocchior\OPAL-RT\RT-LAB_Workspace\XSG_DIO\models\XSG_DIO_RTLAB\netlist\synopsis (Impossibile trovare il file specificato)
at com.xilinx.sysgen.netlist.XTable.valueOf(XTable.java:437)
at com.xilinx.sysgen.netlist.Block.fromXTable(Block.java:441)
I tried to find some similar post but I didn't discover nothing
thanks for every kind of help
Riccardo
Re: Error running xlBitstreamPostGeneration
Hi ,
Could you provide more details ?
What is your operating system ?
Is your Matlab compatible with Sysgen , please check Xilinx Answer Record 17966
Make sure to start SysGen from the start menu, not just through a Matlab/Simulink prompt. This way, the Xilinx environment will be set up properly. If not, it can cause inconsistent errors .
Try clearing your SysGen cache (type xlcache('clearall') at a matlab/sysgen prompt)
-> http://www.xilinx.com/support/answers/37984.htm
Check if it is design specific or machine specific erorr ?
Check killing all openJava programs .
Please let me know how it goes.
Vanitha.
