Newbie shen_linux
HDMI IN of ZCU102
Hi, everybody:
I am using ZCU102 board, but HDMI IN of this board is hard to drive.
I also tried digilent IP, but it only suites ZYNQ 7000.
Are there some examples of this board's HDMI port?
Scholar hbucher
Re: HDMI IN of ZCU102
@shen_linux Yes, but you need to buy or evaluate the necessary IP.
https://www.xilinx.com/products/intellectual-property/hdmi/hdmi-evaluation.html
Xilinx HDMI Subsystem IP can be used with this board. When you select ZCU102 in Vivado, and then add HDMI RX Subsystem IP, right click -> Open IP example design, it generates "ready to use" design for ZCU102 board.
For more details on HDMI example design flow, please refer to chapter 5 of PG236 : https://www.xilinx.com/support/documentation/ip_documentation/v_hdmi_rx_ss/v3_0/pg236-v-hdmi-rx-ss.pdf
Scholar hbucher
@xud yes but I believe he will need a special evaluation license, right?
Yes @hbucher, the details on licensing and order information is documented in page 6 of PG236 : https://www.xilinx.com/support/documentation/ip_documentation/v_hdmi_rx_ss/v3_0/pg236-v-hdmi-rx-ss.pdf
Hi @shen_linux,
Do you have any updates on this? If the issue is solved, please share your solution for everybody and accept as solution.
Florent
