HDMI TX IP bus skew problem
I generated HDMI passthrough example design and add MIG ip and bram ip. After I ran the design, vivado show the critical warning as below picture
And then I opened implemented design and used the bus skew report command
I found all bus skew came from HDMI TX ip.
 The attached is my bus skew report. How do I fix it?
BR,
Sitting
Re: HDMI TX IP bus skew problem
@sitting
I used your dcp to generate timing summary, couldn't see any timing errors. Can you confirm if checkpoint is post-implementation? If so, I think you can ignore the warning.
Hello @sitting
from your report, I can see that all Endpoint Source/Destination & Reference Source/Destination are coming from the same module (XPM_GRAY_INST).
From:exdes_i/v_hdmi_tx_ss/U0/v_hdmi_tx/inst/SYS_INST/CORE_INST/CH2_INST/VID_INST/FIFO_INST/WP_CDA_INST/XPM_GRAY_INST/src_gray_ff_reg*
To:exdes_i/v_hdmi_tx_ss/U0/v_hdmi_tx/inst/SYS_INST/CORE_INST/CH2_INST/VID_INST/FIFO_INST/WP_CDA_INST/XPM_GRAY_INST/dest_graysync_ff_reg*
Could you try to add floor-planning restriction using pblock ? (please see UG906 Chapter 7 for detailed info)
Floorplanning may help your design to meet timing.
Best regards
Leo
Hi @karnanl,
Do I restrict all the HDMI TX or only XPM_GRAY_INST?
Best regards
Sitting
Hello @sitting
You can create floorplan with pblock for HDMI TX SS as a start-point.
Best regards
Leo
@sitting
From the timing report, the source and destination are from different clock domains, the requirement is 3.367 ns. Can provide dcp and xdc file, so I can double check if the timing constraint is correct.
Hi @xud,
Here are the download links:
DCPConstraint
BR,
Sitting
@sitting
I have checked the dcp file, the pink route is the one has the problem. As link_clk and video_clk are both from the same PLL, they are related clock, vphy_clk.JPG
When I run report_clocks, both of them are constraints to 297MHz. For Video_CLK(vclk_from_txpll), it's correct.
For link_clk, 148.5Mhz should be enough. We have reported this issue.
To improve timing, you can use normal timing closure, please try to use a different implementation strategy (eg. performance_explore), and see if it improves things.
Hi @xud,
I will try other implementation strategy. Which vivado version will fix this issue?
Sitting
Hi @xud,
I have tried different implementation strategies, but bus skew problem is still exist. Waiting for your release of new patch seems the best way
BR,
Sitting
No patch is needed, you can manually add constraint to constrain link_clk to 148.5 Mhz, following is an example, you probably need to change accordingly :
create_clock -name link_clk -period 6.734 [get_ports link_clk]
Hi @xud,
There are two constraints in video phy xdc as following:
create_clock -period 3.367 [get_pins -hier -filter {name=~*/XCVR_CH*_INST/gtxe2_i/TXOUTCLK}]
create_clock -period 3.367 [get_pins -hier -filter {name=~*/XCVR_CH*_INST/gtxe2_i/RXOUTCLK}]
Is it possible to change 3.367 to 6.734 directly?
BR,
Sitting
Hi @xud,
I tried to change 3.367 to 6.734 directly and reran implementation. The bus skew issue was solved, but it generated new critical warning as following.
I didn't see any timing issue in timing summary.
Could you help me to check checkpoint as following link?
https://drive.google.com/open?id=1eQ8cRcVEmsy1vXgZ__sfSGRT0fuWVRA5
BR,
Sitting
@sitting
Hi @xud,
  I have checked it again, checkpoint is post-implementation. As you mentioned, I can ignore this critical warning.
BR,
Sitting
