Observer jessexi
HDMI TX Pll type is CPLL,How much is max line rate of HDMI TX?
Hi Xilinx
   HDMI TX pll type is CPLL,in UG476 the CPLL operate range between 1.6GHz to 3.3Ghz.
  TX Max GT Line Rate is 5.94Ghz in vid_phy IP. In my opinion,MAX CPLL freqency and Max GT line rate are conflicting.
    I want to konw how much is max line rate of HDMI TX?
    Device is XC7V485T.
    Thanks a lot
Re: HDMI TX Pll type is CPLL,How much is max line rate of HDMI TX?
@jessexi
The MAX GT Line rate in Video PHY GUI is based on the max line rate needed for NI-DRU, QPLL and CPLL, as it can be configured via driver to use QPLL or CPLL.
Please take a look at table 3-8 (page 70) of PG230 , the CPLL Line rate range aligns with UG476GT_Line_rate.JPG
@jessexi
Hi @jessexi,
Thanks and Regards,
Observer jessexi
Hi xilinx
  sorry for reply late.
  Thanks for your help.
  my issue is solved
