Participant yildizbilgin
HDMI TX Subsystem Example Design
Refer to PG235 chapter5, I followed the steps but I have chosen the design topology as TX only;  and I have generated a colorbar pattern with Zynq Ultrascale+ MPSoC ZCU104. But I want to generate this pattern as 4Kp30. Which things should I change on this design? And how would I know what is the resolution and frame rate of the pattern that I have generated?
Tags (2)
Re: HDMI TX Subsystem Example Design
Hi @yildizbilgin,
These are available in the uart menu.
This menu is available automatically after starting the project and following the hardware setup directions. (setting up the UART)
Xilinx Video Design Hub
Hi @yildizbilgin,
