HDMI TX cannot show
     i learm hdmi 2.0 example on kc325t, so i  make a board for myself,   i use passthrougth mode : start color; 115200 uart send  tx tream is up, but i test tx refclk it is not output. it is 0 MHZ.
Tags (2)
Scholar watari
Re: HDMI TX cannot show
Hi @autelchengpeng
What kind of board do you use ? KC705 ? If original board, would you share schema ?
Also what source and sink devices do you use ? Would you explain details ? ex. source device is PC and sink device is my LCD monitor. Part number is .....
I guess it seems EDID issue.
But it is hardly to find route cause. Not enough information.
Best regards,
Scholar dpaul24
@autelchengpeng
If you are in the learning phase, then I would advice you to use a FPGA based development kit (rather than your own board) for HDMI.
FPGA enthusiast!
All PMs will be ignored
in order to full my guest need , i must use my board.,
@autelchengpeng,
As @dpaul24 has mentioned, we do provide platforms to use as a guide to help learn HDMI and to use as examples. Even if you can not use these for your customer directly, they are good tools to use.
As @watari has mentioned, we do not have enough information here to root cause your issue.
We do not know what you are using as a source for your TX clock. Is your clock oscillator providing the clock that you expect it to?
How does your application work? Are you using parts of our example applications or have you made your own? Is it running as you expect it to?
Using our KC705/KCU105/AC706/VCU118 diagram as an example, our tx_gtrefdk clock is provided from a Si5324 chip. This chip gets the clock either from the rx_tmds clock or from an oscillator. Each of these chips is controlled from the application layer and drivers in our example designs.
2018-12-07 12_35_11-Xilinx Documentation Navigator 2017.2 -  http___www.xilinx.com_support_documenta.png
For the community to be of more help, please provide more details:
  • how your hardware should be working
  • what your application is trying to do
  • what you have done to try and root cause the issue.
Also a schematic, application summary or files, and a log will be helpful to the community as well.
Sam
Xilinx Video Design Hub
Hello, i also use SI5324 , and copy kc705 board sh,
now tx is up ,but is not show,
Starting colorbar
TX stream is up
Colorbar :
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 60Hz
Resolution: 1920x1080@60Hz
Pixel Clock: 148500000
i send i to uart, it relpy:
Info
HDMI TX SubSystem
->HDMI TX Subsystem Cores
: HDMI TX
: VTC Core
HDMI TX version : 02.05 (0000)
VTC version : 06.01 (000B)
HDMI TX timing
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 60Hz
HSYNC Timing: hav=1920, hfp=88, hsw=44(hsp=1), hbp=148, htot=2200
VSYNC Timing: v
av=1080, vfp=04, vsw=05(vsp=1), vbp=036, vtot=1125
Scrambled: 0
Sample rate: 1
Audio channels: 0
HDMI RX SubSystem
->HDMI RX Subsystem Cores
: HDMI RX
HDMI RX version : 02.20 (0000)
HDMI RX timing
No HDMI RX stream
Link quality
Link quality channel 0 : excellent (0)
Link quality channel 1 : excellent (0)
Link quality channel 2 : excellent (0)
Audio
Channels : 2
ARC CTS : 0
ARC N : 0
Infoframe
RX header: 0
HDMI PHY
VPhy version : 02.00 (0000)
GT status
TX reference clock frequency 148504576 Hz
RX reference clock frequency 0 Hz
DRU reference clock frequency 125000000 Hz
TX => CPLL / RX => QPLL0
RX state: idle
TX state: ready
QPLL0 settings
M : 0 - N : 0 - D : 0
CPLL settings
M : 1 - N1 : 5 - N2 : 4 - D : 4
RX MMCM settings
Mult : 0 - Div : 0 - Clk0Div : 0 - Clk1Div : 0 - Clk2Div : 0
TX MMCM settings
Mult : 12 - Div : 1 - Clk0Div : 48 - Clk1Div : 12 - Clk2Div : 24
DRU Settings
Version : 7
DRU is disabled
we sh is here:
GT's bank is same with KC705
hdmi bank:
i can read my screen's edid, information is low:
Enter Selection -> 1 1
Unknown option
--- EDID MENU ---
1 - Display the edid of the connected sink device.
2 - Clone the edid of the connected sink edid to HDMI Rx.
3 - Load default edid to HDMI Rx.
99 - Exit
Manufacturer name : SAM
Raw data
00 : 00 FF FF FF FF FF FF 00 4C 2D 10 0C 53 46 5A 5A
10 : 2B 1C 01 03 80 34 1D 78 2A 7D D1 A4 56 50 A1 28
20 : 0F 50 54 BF EF 80 71 4F 81 C0 81 00 81 80 95 00
30 : A9 C0 B3 00 01 01 02 3A 80 18 71 38 2D 40 58 2C
40 : 45 00 09 25 21 00 00 1E 01 1D 00 72 51 D0 1E 20
50 : 6E 28 55 00 09 25 21 00 00 1E 00 00 00 FD 00 32
60 : 4B 1E 51 11 00 0A 20 20 20 20 20 20 00 00 00 FC
70 : 00 53 32 34 45 33 36 30 0A 20 20 20 20 20 01 85
80 : 02 03 11 B1 46 90 04 1F 13 12 03 65 03 0C 00 10
90 : 00 01 1D 00 BC 52 D0 1E 20 B8 28 55 40 09 25 21
A0 : 00 00 1E 8C 0A D0 90 20 40 31 20 0C 40 55 00 09
B0 : 25 21 00 00 18 8C 0A D0 8A 20 E0 2D 10 10 3E 96
C0 : 00 09 25 21 00 00 18 00 00 00 00 00 00 00 00 00
D0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 51
Enter Selection ->
i use si5324 to create 148.5M it is rigth!  when 74.25M, it is error .   why?
TX stream is up
Colorbar :
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 60Hz
Info
HDMI TX SubSystem
: HDMI TX
: VTC Core
HDMI TX timing
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 60Hz
VSYNC Timing: vav=1080, vfp=04, vsw=05(vsp=1), vbp=036, vtot=1125
Scrambled: 0
Sample rate: 1
Audio channels: 0
HDMI RX SubSystem
: HDMI RX
HDMI RX timing
No HDMI RX stream
Link quality
Audio
Channels : 2
ARC CTS : 0
ARC N : 0
Infoframe
RX header: 0
HDMI PHY
GT status
TX reference clock frequency 148502528 Hz
RX state: idle
TX state: ready
QPLL0 settings
CPLL settings
RX MMCM settings
TX MMCM settings
DRU Settings
Version : 7
DRU is disabled
Starting colorbar
TX stream is down
TX stream is up
Colorbar :
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 30Hz
Resolution: 1920x1080@30Hz
Pixel Clock: 74250000
Info
HDMI TX SubSystem
: HDMI TX
: VTC Core
HDMI TX timing
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 30Hz
Scrambled: 0
Sample rate: 3
Audio channels: 0
HDMI RX SubSystem
: HDMI RX
HDMI RX timing
No HDMI RX stream
Link quality
Audio
Channels : 2
ARC CTS : 0
ARC N : 0
Infoframe
RX header: 0
HDMI PHY
GT status
TX reference clock frequency 222754816 Hz
RX state: idle
TX state: ready
QPLL0 settings
CPLL settings
M : 1 - N1 : 5 - N2 : 2 - D : 2
RX MMCM settings
TX MMCM settings
Mult : 8 - Div : 1 - Clk0Div : 32 - Clk1Div : 24 - Clk2Div : 48
DRU Settings
Version : 7
DRU is disabled
i change you demo,  now it is rigth. what i do pelase look the picture.
i watch colok parameter, it is change when it is XYphy_SetHdmiTxParam, why ?
hello,please help me look at this problem!
Hi @autelchengpeng,
When adding data points, please include as much information as possible in your explanations this will help us to make sure we know what is going on.
Problem:
Your TX output clock is 0 MHz and you do not see the video on the sink device.
Here what we know about your system:
  • Custom board
  • Board follows KC705 design and schematic
  • Resolution is 1920x1080@60Hz Progressive
  • Pixel clock is 148500000 meaning that we are not in DRU range. So no clocking considerations.
Your questions:
  1. i use si5324 to create 148.5M it is right!  when 74.25M, it is error.   why?
  2. i change you demo,  now it is right. what do I do, please look at the picture. i watch colok parameter, it is change when it is XYphy_SetHdmiTxParam, why?
I apologize, I am not sure what you are asking? It sounds like you are looking at the clock and seeing the value change. This will happen when the TX changes resolutions as different clocks are required for different resolutions.
please look at the picture - Please do not edit the driver code! There is most likely not an issue here, but somewhere else in your design.
More Information needed:
  1. How are you checking the frequency of the TX TMDS clock? Oscilloscope? Uart?
  2. Is the frequency still 0?
  3. Are you using our application? Is it set to pass through or TX only (color bar)?
  4. Are you using our example design for the KC705 or some other design?
    1. Can you share this design?
  5. What do you see on the sink monitor?
  6. Is the stream into the TX core locked?
  7. Can you add the System Flow Event log? (VPHY log) I and Z in the uart menu.
Also please take a look at the debug section Appx. C of PG235
-Sam
Scholar watari
Hi @autelchengpeng
Generally, HDMI Tx generates the clock which is multiplied by 10 to transfer data signals.
I guess, in this case Tx IP generates 74.25MHz x 10 = 742.5MHz as transferring data signals.
However, this clock is not suitable HDMI.
So it down's work well.
So, I suggest using correct input clock and not edit driver code.
Best regards,
Hi @samk
 Yes, i use your KC705 application schematic and code example.
 i use TX only(color), and  enter i and z on uart, log is follow:
Starting colorbar
TX stream is up
Colorbar :
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 60Hz
--- HDMI SS + VPhy Example v1.0 ---
--- (c) 2016 by Xilinx, Inc. ---
Build Nov 24 2018 - 21:00:09
Starting colorbar
--- MAIN MENU ---
i - Info
=> Shows information about the HDMI RX stream, HDMI TX stream,
GT transceivers and PLL settings.
c - Colorbar
=> Displays the colorbar on the source output.
r - Resolution
=> Change the video resolution of the colorbar.
f - Frame rate
=> Change the frame rate of the colorbar.
d - Color depth
=> Change the color depth of the colorbar.
s - Color space
=> Change the color space of the colorbar.
p - Pass-through
=> Passes the sink input to source output.
l - GT PLL layout
=> Select GT tranceiver PLL layout.
z - GT & HDMI TX/RX log
=> Shows log information for GT & HDMI TX/RX.
e - Edid
=> Display and set edid.
a - Audio
=> Audio options.
v - Video
=> Video pattern options.
Starting colorbar
TX stream is up
Colorbar :
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 60Hz
Info
HDMI TX SubSystem
: HDMI TX
: VTC Core
HDMI TX timing
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 60Hz
Scrambled: 0
Sample rate: 1
Audio channels: 0
HDMI RX SubSystem
: HDMI RX
HDMI RX timing
No HDMI RX stream
Link quality
Audio
Channels : 2
ARC CTS : 0
ARC N : 0
Infoframe
RX header: 0
HDMI PHY
GT status
RX state: idle
TX state: ready
QPLL0 settings
CPLL settings
RX MMCM settings
TX MMCM settings
DRU Settings
Version : 7
DRU is disabled
VPHY log
GT init start
GT init done
TX frequency event
TX timer event
TX MMCM reconfig done
CPLL reconfig done
GT TX reconfig start
GT TX reconfig done
CPLL lock
TX reset done
TX alignment done
HDMI TX log
Initializing HDMI TX core....
Initializing VTC core....
Reset HDMI TX Subsystem....
TX Set Stream, with TMDS (32)
TX cable is connected....
TX Audio Unmuted
TX Stream is Up
HDMI RX log
Initializing HDMI RX core....
Reset HDMI RX Subsystem....
Hi @samk
     the sink monitor is nothing, the TX core is locked, it is high after tx's up.
     please look at schematic.
here is my demo, base on kc705 demo.
Hi @autelchengpeng,
Did you forget to add an attachment ? "here is my demo, base on kc705 demo."
At this point, it looks like we have confirmed that your clock is correct, but you do not see any video on the monitor. Is this correct or is there another issue? If so, please explain.
Sam
i find the question, my bank is 3.3V, constant is TMDS_33, so colok is not output.
now i pull up clock's pin , 1080P is ok。
  but i use 4K , it is error. why ? please.
In your second image which I believe is for 4K?
It shows that it is unable to set the requested TX video resolution.
Can you attach your logs again (i then z ) for this resolution? Is this a standard 4K or different?
Sam
hello,@
    we find question, we use vivado2017.4, and input sysclk is 100Mhz or below,  TX is ok.
   i think it is sysclk's precision.
Hi @autelchengpeng,
The HDMI core does require that the sysclk is accurate to within 40PPM.
From PG230
Sam
HI @autelchengpeng,
Did you confirm that thie issue was coming from sysclk ? If this is the case, could you kindly close the thread by marking a reply as accepted solution?
Florent
