HDMI to modular media over IP
I am trying to connect HDMI input data(via HDMI RX subsystem) to Modular media over IP subsystem.
However, Modular Media over IP subsystem has only Video AXIS. HDMI RX subsystem  has Audio and Video AXIS.
Any idea how to send the Audio AXIS over Modular media over IP or alternate ways to send it along with Video ?
Asan.
Re: HDMI to modular media over IP
Hi @ajasan,
First I should note that:
This IP Core has been discontinued. Effective Date: 5/24/2017
It is not recommended for new designs. The core is removed from IP catalog as of 2017.2. Please contact Macnia Technology, our IP partner, for available alternative IP.
Second if you choose to move forward with the Modular Medio over IP (which I do not recommend) core it has the:
FC3190 Packetizer Module which Converts audio samples into a media datagram stream in accordance with the RFC3190 protocol used by VSF Technical Recommendation TR-03
I am not familiar with this IP but it looks like the audio and video will need to be transferred using the two RFC4175 and RFC3190 Modules. I am not sure if modules can be combined to output on the same stream.
Xilinx Video Design Hub
Hi @ajasan,
If everything is clear for you, please close the topic by marking a reply as accepted solution.
Thanks and Regards,
Florent
