How can I use VPSS deinterlace under linux?
Hello
I want to use VPSS deinterlace under linux.
But I only find VPSS csc and VPSS scaler drivers under linux system.
so how can I use this mode of VPSS?  Should I write drivers for "deinterlace only  VPSS" like VPSS-CSS ?
Any suggestions? Thanks a lot.
Re: How can I use VPSS deinterlace under linux?
HI @gefei-liuqi ,
You are right, as per the wiki page listing all the available drivers, there is no driver available yet for the VPSS used as deinterlacer. Your main choice is to create the linux driver by yourself. Another option would be to use another processor (like a small microblaze) to control the IP using the baremetal drivers.
From my understanding you will not use the same CMA buffer for both the VCU and the deinterlacer. But yes you would need to allocate memory for the deinterlacer
Hope that helps,
Florent
My board is ZCU106.
The VPSS deinterlacer needs memory, and the VCU needs memory also. So should I increase the sizeof CMA?
HI @gefei-liuqi ,
Hope that helps,
Florent
