Visitor jackielee
How to configure VDMA to transfer only one frame?
We want to transfer a 640*480 picture by PS,first,we write it to DDR,and transfer it to PL by VDMA.We just want to transfer it once,then stop,but the VDMA transfer the same picture continuously.We configure the VDMA as follows:
We use ILA to see the wave as follows:
According to the result,we can find the TVALID signal get down,but then the signal return to 1 and continuously transfer the same picture.
Tags (3)
Re: How to configure VDMA to transfer only one frame?
Hi @jackielee,
 Check the control register for the VDMA (offset 00h).  On bit [23:16]:
"The minimum setting for the count is 0x01. A write of 0x00 to this register sets the count to 0x01. When DMACR.FrameCntEn = 1, this value determines the number of frame buffers to process."
Then just set FrameCntEn = 1 + [23:16] = 0
Mentor watari
Mentor
Hi @jackielee
I'm not sure. But at least your code has some wrong settings.
Refer the following suggestion.
- "MM2S_HSIZE" (54h) => This unit is NOT pixel. It's byte. In this case you need to set 640 * 4, if your color depth and color format is 24bit/RGB (RGB888) or 24bit/YUV (YUV444) or 30bit/RGB (RGB101010) or 30bit/YUV (YUV444).
- "MM2S_VSIZE" (50h) => It seems wrong. It might set 480.
Visitor jackielee
Thank you for your replying,it seems the realy point is not your said.The point is to make VDMA just transfer one frame.Thanks again.
Hi @jackielee,
Visitor jackielee
thank you very much.Your answer is very good.
